Problem sli gtx680
simous
Hello has all I am new on the forum and I am very satisfied to be among here you 🙂
are my configuration
3930k
sli gtx680
R4E
2x4go ripjaw-x
2133 9.11.9.28.2t
hcp 1200w
vertex3
I have a problem with my pc since to install(settle) my sli gtx680 when I throw(launch) a bench 3d, as 3dmark11, vantage, heaven etc. my computer goes out just like that at the end of some second of bench and restarts otherwise everything test occt, linx, prime95, intelburntest, etc. are stable even, wprime and cinebench and 2 last test cpu of vantage whether it is has 4.5ghe or has 5ghz work perfectly
I can play has bf3 or crysis 2 during several carefree hours but not of bench regrettably : (
I have to test pins one by one with memest, and to test every 680 separately with the pilot(driver) 301.10 and 301.24 but nothing makes for it with my sli of gtx580, I had nobody concerns(marigolds), even there bench with 580 has 1ghz
if you have an idea, I thank you for it beforehand 🙂
8 REPLIES 8
Menthol
Level 14
Are you overclocking your video cards, I just got one GTX 680 today, and while testing overclocks it rebooted once during 3DMark 11 when I went to high on the overclock, but most of the time it just stopped and gave a driver error, backed down on the overclock to 1245 GHZ on the core and all works good. I do have another coming to sli soon. I'll be testing them together soon. Other than overclocking, heat would do that.
HiVizMan
Level 40
Could you run your cards one at a time at stock, and then together at stock and see if the crash happens.
I have two cards still in their boxes that I could test when I have time but time is not something I have much of right now. But if you have the latest drivers and the latest DirectX then all should be good - at least at stock.
Thank you, of your answer
I succeeded has to finish one 3dmark11 with them gtx680 stock but impossible to begin again, the computer goes out I have to try with one 680 but the computer goes out similar, with 2 x 680 similar, same overclockée, the computer goes out here is the score 3dmark 11:
http://3dmark.com/3dm11/3187437;jsessionid=b2qxcpaqwjdx1n1g5e2lrsvgz
I have to leave the computer put out(switched off) during the 1 hour, and I succeeded has to cross(spend) the 3dmark11 with 680 stock but impossible to begin again second time I have the impression(printing) that there is a power cut just like that or that the food(supply) puts itself in safety(security) or that the cpu puts itself in safety(security)
HiVizMan
Level 40
Your PSU should be up to the task I run one - the same kind (actually three) for my benching rig.
But I am struggling to understand what you are saying. Short sentences please. Your system is overclocked. It is stable? Your cards are stock?
What drivers?
What are you using to overclock?
OK, to sadden for the translation I am French
my system is very stable
cpu 4.5ghz 1.27v
sli gtx 680 stock frequency
driver: 301.10
http://www.techpowerup.com/gpuz/bkuv9/
http://valid.canardpc.com/show_oc.php?id=2322472
The problem, it is bench 3d, the computer goes out
You have both 6 pin connected on each card right?
kz9
What cards are they? I forgot to install the updated Asus GPU tweak and had nothing but troubles with them. I DL the lastest GPU tweak and now have them running @1200 in SLI
Does the whole computer just turn off?
HiVizMan
Level 40
Use the latest Beta drivers they work very well with the 680 cards.
