Problem installing AI suite on W10
ExnerGO
I recently updated to Windows 10 Education and now I'm not able to install the AI suite software, everything else works just fine, my windows is updated but the installer for the Ai Suite just doesn't open doesn't matter what I do. I'm guessing is have something to do with my windows being an Education version but Idk how to know for sure...
Can someone please help me?
MeanMachine
Check your Task Manager for a process called axinst.exe. End that process and the installer should magically start working.
You should also install as "run as administrator".
Also which version are you installing ver2 or ver3. ?
If it's latest version of AISuite III, right click on the zip file, properties , and click the big button that says Unblock and hit apply.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
