10-13-2011 02:44 PM
10-13-2011 02:57 PM
10-16-2011 02:51 PM
10-16-2011 04:35 PM
10-17-2011 04:14 AM
Kipper wrote:
IC Diamond is some good stuff but you dam near need a bulldozer to spread it, crap is dam near a sold. LOL
10-17-2011 12:18 PM
FiNAS wrote:
I used AS5 for the past 6 years until I decided to try a bunch of them on january. I tried 7 diferent of the most rated brands, and IC Diamond came out on top. The diference to AS5 is amazing.
having said that, the thing is hard as hardened cement! but I found a solution: heat up the siringe by dropping it on hot water and heat up the cpu and cpu-block surface with a airdryier. That will make the the IC diamond spread like butter.
10-18-2011 10:55 AM
10-17-2011 08:10 AM
10-17-2011 10:35 AM
