Hi AfTaStEr
😄Performance hits are generally due to 3 things. (barring hardware faults)
1. Power Plan settings.
Check your Power Plan in Windows. Open Control Panel> Power Options. Choose High Performance.
2. Throttling due to core temperature.
If this is the case, you need to conduct a stress test to determine if heat is the cause when under load. Have you OCed the system?
3. Bios settings.
You may have to Tweak your Bios.
Go here for a good read on how to OC your processor:
http://rog.asus.com/5052012/overclocking/crosshair-v-formula-amd-fx-8150-cpu-overclocking-guide/ and here:
http://www.overclock.net/t/1348623/amd-bulldozer-and-piledriver-overclocking-guide-asus-motherboardPlease report back with results.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
