@raja@asus - Question: When, if it is possible through the bios, will Asus separate the voltage offset from effecting C-states other than C0?
The primary problem with voltage offset is that it automatically offsets all C-state values by the same amount as C0 for load conditions. If there is a way to separate the C0 voltage offset from all other C-states, whether by pegging all other C-states to a static voltage or individually calibrating (or allowing the customer to individually calibrate) the voltage offset for each lower C-state (C1-C7 on the 4790K), wouldn't this prevent the boot problems, remove the problem of enabling Adaptive for voltage offset OC when it provides too much voltage to the Vcore, and allow for a lower offset than that possible by static pegging of voltage for C0? It seems that this is the simpler, more elegant answer than adaptive (although, admittedly, may cause a major bios rewrite to separate the varying voltages of C-states and the voltage offset of C0). I believe this would expedite the adoption of voltage offset while utilizing Haswell and future processors additional C-states for lower energy consumption.
joesaiditstrue wrote:
Is it true that using offset voltage can cause errors/bios instability in the Maximus V Extreme, specifically with the management engine? I've always previously used offset rather than manual voltage and had to return a board two or three times due to "ME Version: N/A" and read somewhere that it could be tied to using Offset voltage control
This isn't true. Read my post. By doing voltage offset, you can do a negative offset that affects a lower C-state for idle voltage. Because it makes this voltage too low to operate at that frequency, it causes stability issues. Not problems with the ME!
