Odd sensor problems
shingara
I keep getting warnings for voltage at +4.99 and temps at -128.8. now obviously as my pc isnt in flames and isnt sat inside a fridge is this ai suite playing up or is it something like a faulty psu ?
On bios 2002.
4 REPLIES 4
skellattarr
Level 11
you can't have ai suite and another sensor reading software reading the sensor at the same time it will give you wrong readings and warnings just run one program
amd ryzen 9 3950x
CROSSHAIR Viii hero
Corsair Hydro Series H115i
G.SKILL Trident Z 3200mhz 64gb 4x16 timings 16,18,18,38
asus rog strix gtx 1080
TOSHIBA 3TB hdd 3x a total of 9tb, 10 tb hdd and a 1tb mushkin ssd
corsair axi 1200i 1200 watt psu
thermal take view 71 case
shingara
Im aware of this, i dont have any other monitoring software, my corsair cooler doesnt read anything apart from the h100i. This is what is making me think that my psu is on its way out.
meankeys
I would not use AI suite. I find it must give you an average temp not your actual core temp. use core temp and CPUZ they are the most accurate.
madcratebuilder
Get rid of ai suite and use a good monitoring software like HWInfo64. Don't worry about a 5v reading of 4.99v, these are software readings and not 100% accurate. Use a quality DVM for checking voltages.
Speedbird 9590@5.1/CHVFZ/8gb G Skill@2133/ASUS R9-280X all on EK blocks controlled with Aquaero 6 Pro
Goonybird 8350@4.6/GA990FXAUD3/16gb Corsair@1600/Crossfired Sapphire 7990's cooled with CM 240L XSPC res
