The first thing I would suggest you doing is reading the guide that are found at the top of the sub-forum. They are really well thought out and will provide the background information you need to make sense of what is going on.
You used the term 8 channel? Could you explain what you mean by that. If you are using 8 sticks of ram you will need to manually set your ram, as XMP will not in most cases work. The XMP profiles are for a single kit of ram.
