No q-fan control for cpu_opt R4BE
astroice
I have an AIO cooling setup Nepton 280L for my R4BE. Have the pump on the cpu fan plug and the radiator fans on the cpu_opt plug. In the bios there is no q-fan controls for the cpu_opt. Would it be best to put the radiator fans on something else?
Have not started to tweak anything yet, just getting everything setup.
Any thoughts?
HiVizMan
Level 40
Quick question is there a reason why you are not using the CPU fan header?
Raja
Any thoughts?
The CPU_FAN and CPU-OPT headers are tied. If you control the CPU fan header, the OPT header gets the same settings applied - they are not independent agents. The only thing you need to bear in mind is that the CPU-OPT fan header will not control 3 pin fans (4 pin only), while the CPU_FAN is 4pin and 3pin capable.
HalloweenWeed
Level 12
I use both the CPU_FAN & CPU_OPT headers. Each goes to a "Y" cable so all 4 of my p-p fans go the same speed (see my pics in my ModsRigs, sig below).
FYI on the RIVE only CPU_FAN (& CPU_OPT) & CHA_FANx headers are speed controlled. Depite the appearance of an adjustment in the BIOS the OPT_FANx headers keep those fans at 100% constantly. I wonder if the RIVBE is the same way (you would need to plug in 4-pin true PWM fans to find out).
i7-3930K; Asus RIVE; G.SKILL Ripjaws Z 4x4GB DDR3 1866; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB;
Corsair 1000HX; Corsair H100, 4x Excalibur 120mm PWM CPU Fan p-p, AS5; SB X-Fi Titanium Fata1ity Pro;
Dell U2412m IPS 1920x1200; Cooler Master HAF 932 case; Tripp-Lite OMNIVS1500 UPS fully Line-interactive.
(EVGA site: ) And I have a second (wife's) computer, Eve.
Overclocking is useless to me if it is not rock stable.
