No Intel Management Engine in RIVE?
Yoshi__s
I have a new Rampage IV Extreme board with an Ivy Bridge-E processor (BIOS 4403).
In the BIOS main page it says:
ME version: N/A
Not available? What does it mean?
I downloaded the Intel Management Engine firmware 8.1.51.1471 and when I execute the MEInfoWin64.exe (just to know what version I have): I get the following errors:
Error 8193: Intel (R) ME Interface : Cannot locate ME device driver
Error 9459: Internal error (Could not determine FW features information)
How is it possible? My RIVE doesn't have Intel Management Engine? I don't understand...
How can I activate it?
Thank you very much.
20 REPLIES 20
HiVizMan
Level 40
Just a quick question what do you use the IME for?
And I just went to the Rampage IV Extreme support page and there is MEI under the chipset drivers
Version 9.0.0.1287
Description Intel(R) Management Engine Interface V9.0.0.1287 for Windows Vista/7/8 32bit & 64bit.(WHQL)
xarot
Level 11
Do you mean in BIOS you cannot see any version? Did you try to reflash BIOS, I am not sure if you'd need to try to update the IME BIOS on it's own?
Your post got me excited, is the full BIOS available through IME? I could do some overclocking/voltage adjustments/execute stability tests from workplace, and see if there's a BSOD on screen, reboot the system.. etc. 😄 Just need to figure out how to setup a remote connection to my LAN.
Looks like the same like ILO I've seen on HP servers.
Main: i9-10980XE - Rampage VI Extreme Encore - 64 GB G.Skill Trident Z Royal 3600 CL16 - Strix RTX 3090 - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB - Water cooling
HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1050TI - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
All around: i9-7980XE - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX3090 - Phanteks P500A - Samsung 960 EVO 512 GB - Water cooling
Yes, I cannot see any Intel Managemet Engine version from the BIOS. It shows NOT AVAILABLE.
I flashed version 4403 when the MOBO arrived to my house 15 days ago, via USB Flashback. Because I had bought MOBO+CPU, and the CPU is an Ivy Bridge-E, which is supported only in version 4403 (there are no newer or older BIOS available for my processor).
I am going to reflash 4403 BIOS and I will tell you.
Yoshi__s
I downloaded the lastest 4403 BIOS: Rampage-IV-Extreme-ASUS-4403.CAP
I rename it to R4E.CAP and from the BIOS I execute EZ Flash 2 programme.
When I select the file to flash, it says: "Selected file is not a UEFI BIOS!"
What does it mean?
What does it mean?
Is your USB stick FAT formatted?
I really put it in C:
I will try with a USB formatted in FAT and also from USB Flashback (but I don't think it works, if I understand what Praz is saying).
Arne_Saknussemm
Level 40
You have a second BIOS on that board. I hope you have left it as it came. If so change to BIOS 2.....copy BIOS to BIOS 1. Now start again, change to BIOS1 and reflash a newly downloaded version if the file. If NA appears in ME in BIOS your flash has not gone well....
Yoshi__s
No, I'm sorry, I have in BIOS2 the same that in BIOS1, I copied 4403 from 1 to 2 because the BIOS that came with the board wasn't compatible with my Ivy Bridge-E CPU, and I wanted to have both BIOS working because if the BIOS1 failed during an update or something like that, i wanted a working BIOS2.
EDIT: Same issue when booting from BIOS2.
Necrosan
Level 12
You will manually need to flash the MEI region of BIOS or RMA the board.
Use FTK to flash the latest region from a backed up copy manually as you can't use standard updates if you've messed it up so bad the system doesn't see it.
MB: ASUS Rampage IV Black Edition
CPU: Intel Xeon E5-2697 v2 (Cooled by Corsair H100i w/ Noctua NF-F12 fans)
RAM: 64GB G.SKILL RipjawsZ 1600 (10-10-10-30)
GPU: EVGA GeForce GTX Titan X Hybrid
TV Tuners: 2 * Hauppauge HVR-1800
Case: CoolerMaster Cosmos 2
