network card doesn't work from cold boot but will after reboot
scotth
I just built this system and when I power it up from cold the network card will not initialize. It won't even show up in the network manager. If I reboot the system it works fine. The drivers initialize and the network card works perfect. I downloaded the latest Intel drivers and played around with some of the power settings but it didn't help.
Motherboard model: Rampage IV Extreme
UEFI Version: 2.10.1208
CPU: Intel Core i7-4820K 3.7GHz
Memory kit: G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200)
GPU: MSI GTX 970 GAMING 4G GeForce GTX 970 4GB 256-Bit GDDR5
SSD/HDDs/Optical drives: Seagate Barracuda ST500DM002 500GB 16MB Cache SATA 6.0Gb/s 3.5
Pioneer Black Blu-ray Burner SATA BDR-2209
PSU: Coolmax ATX 1000 Watt
USB Devices (model/version number): CH Products, Pro Throttle, Combat Stick, Pro Pedals,
Logitech G11 Keyboard
Monitor: HP LP2465
CPU Cooler: Intel
PC CASE: ATX Mid Tower
Operating system: Microsoft Windows 7 Professional 64 Bit, Activated-yes
Drivers Installed (include version): Intel ver. 12.10.29.0 date: 5/2/2014
Any third Party temp/voltage software installed: no
System Overclocked (provide details): no
7 REPLIES 7
neyuru
I have an idea: go to system manager in Windows and verify that your network adapter has no power saving options enabled.
[/HR]
Rampage IV Extreme BIOS 4206
Intel I7-3820
32 GB Quad Channel Kingston Hyper X Genesis
2 x Nvidia GTX 690
2 x WD Velociraptor 250 GB RAID0
Intel 120GB 320 SSD
Noctua NH-D14 SE2011
CM Silent Pro Hybrid - 1300W
CM HAFx
scotth
I'm assuming that you are referring to this?
I had already tried turning all the options off.
43758
neyuru
Right click mypc, then properties, device manager and then right click your network adapter. I don't have a pc in front of me now but i think that's the correct route. Any power saving options should be disabled.
[/HR]
Intel I7-3820
2 x Nvidia GTX 690
Intel 120GB 320 SSD
CM HAFx
I'm going to call Asus on Monday. I had already tried to disable all the options as you can see in the picture I posted. I also disabled the only LAN option I found in the BIOS. I can't believe that it's a bad NIC chip since it works perfect after reboot. There has to be some driver load issue on a cold startup.
neyuru
I had access to a pc and can confirm that those where the settings i was referring to. Sorry but have no more suggestions at the moment.
[/HR]
Intel I7-3820
2 x Nvidia GTX 690
Intel 120GB 320 SSD
CM HAFx
You don't have your motherboard set to Allow Network to tun on PC, do you?
scotth
I understand what you were asking qdemn7. I turned off those options and you can see by the picture that they're off. I also went into the BIOS and the only option is to either enable or disable the LAN chip, no other options. I called ASUS today and tech support is working to help me resolve the problem.
