Your LLC is very high. I don't think you need it that high. Medium should be enough.
Also, did you change the CPU voltage freq to manual and set it at 500kHz, or was it always like that? You should try to keep the switching freq as low as you can. The higher this value is, the faster the VRM can respond to changes in CPU current requirements, be at the cost of heating up the VRM. If you ran at a lower freq without any issues, then all you're getting from a higher freq is more heat.
Motherboard: RIVE (3602 bios)
CPU: Intel 3930K @4646MHz
OS Drive: 2 X Samsung 840 PRO (Raid 0)
Storage Drive: 2 X 1.5TB WD Caviar Black RAID 0, 2 X 3TB WD Caviar Red, Kingston V100 256GB SSD
Memory: 64GB G.SKILL Ripjaws Z (F3-12800CL10Q2-64GBZL)
GPU: Gigabyte GeForce GTX580 @795MHz - 1536MB GDDR5
PSU: OCZ ZX1250
Cooling: Phantek PH-TC14PE
OS: Windows 7 Ultimate x64. (EUFI)
