Hello All,
First I appreciate your replies.
To the first reply, HiVizman, are you sure it would have a profile AFTER the board has been out for almost two years? This memory is very new. I know they have had bios updates on Asus website off course. But as usual it doesnt say flat out on the memory it supports that this memory is supported.
To everyone else and even HiVIZMAN, if he is correct should I indeed try to find this profile or set the timings myself? As I thought I understood, each timing is suppose to be specific to the board and memory. At least that's what Crucial always led me to believe when I bought their memory, I'd e-mail them with my set up and they would e-mail me some timings to use.
I wanted to use AMD, because I felt with an AMD Proc, and well a mostly AMD board aka chipset etc, that it would be a good match.
So folks what do I do? I want to get the most performance out of that memory that I can. 154.00 bucks isnt really all that cheap if you cant maximize the memories potential.
thank you all very much,
:cool: 😄
