this one is really weird. the computer boots up to my ocz ssd normally and works great but after the bios loads mbr error shows up. I press enter and it boots right away. I thought mbr error was a reinstall error that caused critical problems! does anyone know what is wrong with my mobo or is it simply a setting In the bios that im doing wrong. ive got it on ahci mode in port 2 or 3 I think and like I said after pressing enter it boots up really normal. happened after I cmos reset when overclocking my 8150 to 4.5 which is stable now, but its kind of annoying and worrysome to see such an error that seems to mean nothing? thanks for the help.
my system ocz vertex 4 ssd with latest firmware
crosshair V
amd fx 8150 oc'd to 4.5
cfx 7870's oc'd to 1134
16 gb gskill ram. yes it is on the list. 1866 MHz oc'd to about 1820. didn't like the xmp for some reason
850W psu and corsair 500R case
