Need help running CMT8GX3M2A2000C9 at rated speed on MIVE-Z
owcraftsman
I need help configuring my system to run my CMT8GX3M2A2000C9 at rated speed of 2000 C9.
I'm manual overclocked running vcore w/offset mode. I have no desire to run XMP mode of overclocking so don't suggest that. However, in checking my bios after installation, there is one XMP 1 mode available which is to run 1866 not 2000 anyway so it wouldn't work for my stated goal. I typically use the bios to select the designated speed which was fine for the CMZ8GX3M2A1866C9 which these replaced because 1866 is selectable from the drop down in bios however it jumps up to 2133 after that and there is no in between of 2000 for a selection. I bumped Vdimm to 1.65v manually because it was defaulting to 1.5vdimm and 1066 speed to try 2133 w/ all else on auto but system would not boot at the current clk speed I'm running and I have not tried default clocks. My desire is to remain overclocked at 4.8 which was P95 18 hrs stable running the CMZ8GX3M2A1866C9 at 1866 2t. That took a bump of VCCSA or VCCIO to 1.1v vs the default I'm aware possibly higher would be needed to run 2000. My CPU PLL was lowered to 1.65 from default which should not make a difference but I thought I'd mention it just in case. When I chose 1866 it defaults to 1.5vdimm 9-9-9-24-CR1.
If there is anything I forgot or you need to know don't hesitate to ask I'm just eager to run these modules at rated spec.
If it is not possible to run at rated speed based on motherboard limitations could someone recommend what would be the best settings to run these modules. i.e. 1866 8-8-8-???? CR? 1.6v?
Current system specs:
CPU: Intel i7 2700 @ 4.8 1.408/1.080vcore (load/idle)
Motherboard: Asus Maximus IV Extreme-Z 3402bios
Memory: Corsair CMT8GX3M2A2000C9 1.65v (manual)
GPU: EVGA 015-P3-1582-AR
PSU: Antec HC Pro 1200w
SSD: Kingston Hyper-X 3K 240GB (OS)
| Ryzen 9 3900X | ASUS ROG C8H | Trident Z Neo 4x8 3600 C16 | EVGA RTX2080Ti Ultra | EVGA Supernova 1000 G2 | Corsair 1TB MP600 (OS) & Samsung 970 evo 1TB M.2 (Games) | Custom Enthoo Luxe | EK-Quantum (CPU & Mobo) | Hydro Copper (2080Ti) | Custom external loop w/Phoyba Xtreme Nova 1080 |
4 REPLIES 4
HiVizMan
Level 40
First up these sticks are not designed for the chip-set, processor you are using. And there is no way you will natively get them to run at 2000Mhz.
You have two choices, either run them at 1866MHz (or 2133MHz) or see if your system can overclock the sticks using BCLK. Both of these I suspect you have done.
The how of doing that is pretty much up to your IMC (CPU) and willingness to play with the voltages of the different BIOS settings. Sorry to say no quick fix.
owcraftsman
Thanks for the reply this is pretty much what I expected my bad for trying to pair these with this system. I wish I had done better research before buying them. The IMC seems pretty strong as I have run 16GB all 4 dimm slots populated at 1866 and 4.8 clock. Somehow I thought I could go the 2133 but have had no luck with that yet. For the minute gain I may have gotten it was an ill-conceived notion from the get go. At least these run 1CR vs the 2CR of the vengeance memory @ 1866 and look pretty cool. Would you have any suggestion for timings I might use at 2133? I'm considering 9-11-10-30 CR2 with a bump from 1.1 to 1.2 vccio. Any suggestions would be appreciated before I unload these in the market place.
HiVizMan
Level 40
Vccio 1.25
Dcore 1.7
9-11-10=30 1T
Should work.
owcraftsman
Interesting I'll have time to try that tomorrow and get back TY
