Hi
I'm new here, but I have been building my own computers since the 90ies, and overclocking most of my builds, so I have some experience. This is my first higher end machine with such an advanced mobo though. It seems to be rock stable at default speed and with just the memory overclock by XMP, but even a moderate 4.1 ghz OC is not stable and I would really appreciate some pointers on what I should do. The plethora of settings in bios is somewhat confusing to me....
Spec's
Asus Rampage IV formula with bios 4601 (earlier 4502, 4403)
Intel 4930 with Noctua Nh-D14 with Noctua paste
4x8 GB G.skill Ares F3-2133C10Q-32GAB CL 10-12-12-31-2, 1.6V - this memory is supported my the mobo, but there is no "(Ivy-bridge-E)"-designation
http://www.gskill.com/en/configurator?manu=29&chip=28&model=68Super flower golden King 1000W PSU (platinum, apart from the goofy name it is fairly good
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=252 )
Palit super jetstream 780 SLI with 331.65 drivers at pci-e 1 & 4 (3rd red slot)
256 gb Samsung 840 pro SSD as main harddrive + 2 mechanical drives mirrored raid configuration (windows raid)
Corsair m90 mouse, Corsair K60 keyboard, Overlord 27'' IPS monitor 2560x1440@96 hz, Corsair 600 case
Win7 64 professional (legit copy) I did a new installation for this build. Also running are Symantec end point protection & Corsair m90 mouse configuration program and Asus AI suite II. I have installed the latest drivers from Asus except that Intel managment engine as I don't trust it. I first had the Creative X-fi installed but removed it to see if that was the problem. Now I am just using the latest Realtek drivers from Asus.
Tests:
System at default speed (3.9 ghz), but with memory @ 2133 hz
Prime 95, tested stable for about 10.5 hrs, temperatures at about 60 deg. Celcius
Gaming: Bf4 & Bf3 stable
First goofing around
I overclocked using AI suite II to 4.3 ghz (memory is then set at auto which is 1333 mhz with timings 9-9-9-29-1, 1.5V), ran prime 95 and it seemed stable but when playing bf4 the machine locked hard after a while (not being able to make a crash dump, sometimes not even getting to the blue screen), I tried upping the voltage to the cpu, didn't help. Then I lowered the overclock to 4.1 ghz, but with the same result. I then started to make notes of the further testing.
After my first failures my prime suspect was the memory, so I tested that:
All 4 sticks of memory tested in memtest 5.01 at the same time, 10 hrs @ 1333 hz without errors using single core setting in memtest, I also ran half an hour at 2133 mhz without errors. A strange thing was that regardless if the memory was put at 2133 hz (XMP 10-12-12-31, 1.6V) or 1333 hz (auto, 9-9-9-24, 1.5V) in bios, memtest reported it going at "1550 hz DDR3101 with timings 19-15-15-31 @192 bit mode". Using multicore setting in memtest (all 6 cores) will crash it at test 7, but I believe this is an flaw in memtest (?).
4.1 ghz with TurboV Evo CPU level up
Asus PC diagnostics ok, memory running at auto (1333 mzh), Real temp showed 25-32C idle and 58-67C load with prime 95 (slightly lower, c. 58-60 C, reported in AI suite). It seemed stable until I also surfed around in firefox, after a while the computer locked up.
4.3 ghz with TurboV Evo CPU level up (vcore at 1.275V idle, going to 1.314 V at load)
Ran prime 95 for about 1 hour before blue screening (stop 0X00000124)
4.3 ghz, upping the Vcore to 1.28V in bios and changed some other settings (not really knowing what I did): cpu current capability auto to 130%, cpu power phase auto to extreme, VCCSA current capability 100 to 110%
I ran prime 95 and the temps eventually went up to 66-70 C (most commonly at 64-67 C). Prime 95 + surfing around was stable for 1 hr 15 min, but after shutting prime95 down and started gaming instead, the computer locked up after a while. Tried one more time with the same result.
I down clocked again to default and gaming was stable (well some soft crashes in bf4, which is expected, but no locking up).
I once again oc:ed to 4.3 ghz and ran prime 95 stable for 7 hrs. Probably locking up again when gaming (forgot to write down what happened).
Lowered oc to 4.1 ghz with TurboV Evo CPU level up, vcore was at 1.25 V
Locked up fairly quickly in prime 95
I tried upping the Vcore to 1.28V, but it locked up after 15 minutes in prime 95
My graphic cards (780 SLI) are factory overclocked and even though I used these with the same psu in my last computer (2500K@4.4 ghz, Asus p8p67pro, 8 gb Corsair vengance DDR3) without any stability issues at all, 4930 is more power hungry, so I figured the psu might not cope. So I disabled SLI in Nvidia control panel and then disconnected the lower graphic card by disabling that PCI-lane and removed the SLI bridge (the two pci-express power connectors were still connected though) and tried once again 4.1 ghz@1.28V, but it locked up when gaming again.
I tried using just the other graphic card, this time removing the pci power connectors, but locked up again when gaming.
Temperatures does not seem to be the problem. I am leaning towards that the cpu needs more current, but using fairly high vcore (1.28V) for such a light overclock as 4.1 ghz did not help. What do you suggest I try? Any settings in the bios that are relevant to try?
