Need guide to OC 4790K on M7F
DonWuLFF
Hi, I have post for this on Z87 mobo,if that can help to describe anything.
I just change from M6F,still using H100i and change my 4790K batch,using the same setting. But before that,default bios,run Heaven benchmark,temps reach 60 and what I notice is,the core voltage reach 1.26-1.28(default bios setting,no adjust). Is that normal?
Then I tried prime95,temps 80-90,with default setting. Vcore is high as I mention earlier,then I restart and into bios,set core voltage to 1.25 and cpu core ration to 44.
Run the prime,temps still high. Re-do the bios setting,set core voltage to 1.20,temps down a bit but still in 80-90 range.
Question is,can I set lower core voltage? Any setting for me to start from?
253 REPLIES 253
Nate152
RHracing
Nate,
Thanks for all your info in this thread. I was able to over click my 4970k easily to 4.7 @ 1.30
It fully ran through Rog's 15 minute stress test and test. With custom water loops highest temp was 71.
Thanks to Donwulf for trying all he did as well
Racing
RHracing wrote:
Nate,
Racing
Welcome to ROG formum RHracing.
Glad that this thread able to help you and hopefully to others too.
Nice temp you got there. 🙂
DonWuLFF
Hi TTR45,its good.
Anyone else might share their clock for this?
