Need Fan Xpert 2 for Rampage-IV-Extreme
stim
Will there be any "All suite2" updates with FanXpert 2 for RIVE soon? Tried to install "All suite2" for Maximus V Extreme, FanXpert 2 installed successful but error when i tried to open it.
FanXpert 2 would be nice for even RIVE...
BTW, I missing profile "Intelligent" and "Stable" in my FanXpert 1, wrong version? From manual:
Intelligent: automatically adjusts the CPU fan speed according to the ambient temperature.
Stable: fixes the CPU fan speed to avoid noise caused by the unsteady fan rotation. However, the fan will speed up when the temperature exceeds 70°C.
I never seen it on any other version though so i'm not sure what's going on.
7 REPLIES 7
Metaltoby
I've got the same error with Fan expert but you can alter your fanspeed in the Bios with fan control.
l Asus Rampage 4 Extreme l intel 3960X@ 4800Mhz (1.4 volt) 24/7 l 3x Sapphire HD 7970 1200Mhz/1600Mhz Corsair Dominator GT 16GB DDR3 2133 CL9 l Enermax Max Revo 80+ 1500W l OCZ Vertex 3 Max Iops 120Gb l l OCZ Vertex 4 128GB l Samsung F1 1Tb l Samsung F1 500GB l Corsair H100 l CM Storm Trooper l Dell Ultra Sharp U2711 l 2x Verbatim Store N' Go 2 TB USB 3 l Dell Ultra Sharp U2711 l Logitech X-230 l
stim
I alter fanspeed in Fan Xpert, there are more control here than in bios. Better overview. But i thinking on Fan Xpert 2 uppdate, if it will be avalible for RIVEs AI Suite II also. Its looks nice and have more control and function.
Asus JJ presents Fan Xpert 2 in this video http://www.youtube.com/watch?v=4i-aTUMuIB0
Controlling each fan individually, speed, rename etc looks very nice.
izajasz
I support Your request. I think they shoudl release new AI Suite and especially new fan xpert for Rampage IV Extreme as it is flagship.
MOBO: MVIE BIOS 1402 stock
CPU Core i7 4770K
RAM: 16GB Corsair Dom. Platinum CMD16GX3M4A1866C9 in XMP, SPEC: http://bit.ly/Z56xfm
SSD/HDD: OS-SAMS 840Pro 256GB, APPS - SAMS 830 512GB, DATA - Seagate ST1000DM003
GPU: 2x EVGA GTX 680 FTW+ in SLI config (UEFI BIOS)
AUDIO: Onboard
CPU Cooling: Corsair H110
PSU: Seasonic Platinum 1000W (SS-1000XP)
CASE: NZXT Phantom 630
DISPLAY: ASUS VG278Q (120Hz)
Fan Xpert 2 is not compatible with X79 platform. At least not right now.
This is the feedback I received from Asus tech support, and I posted the original message in my thread as well.
Any update on Rampage-IV-Extreme compatibility with Fan Xtreme 2?
I've posted a topic about this as well - I really miss it from my MVG 🙂
I don't know why the software for the Rampage boards can only control the CPU and Chassis Fans separately (ie all Chassis fans are grouped together)?
This is a bunch of crap because the sabertooth x79 has a GREAT fan control suite of software that comes with it & is so powerful and versatile i see no reason the RIVE can't do it either. This just seems lazy and i'm upset with my RIVE enough as it is -having to spend 200$ on an aquaero to control fan speeds the way the motherboard software is lazy and doesnt let it do is pathetic, even with the better fan expert2 software, spending 200 on a fan controller (its the only one that can do what the sabertooth x79 fan control software did) is the reason I wont be getting an asus board for x99, or any other build later because it shows a lack of care for their customer.
Why put the best thermal management software on the mainstream product but NOT the enthusiast one that costs twice as much? To promote sales of both products? Who would put two x79 boards in one computer besides 0.001% of the population? Sure to get lots of sales that way, asus. Thanks a lot guys - I appreciate the effort here
