09-30-2012 07:41 PM - last edited on 03-06-2024 07:15 PM by ROGBot
09-30-2012 11:21 PM
09-30-2012 11:31 PM
Arne Saknussemm wrote:
Did you catch the codes on the BSODs? As you can see you don't have to run prime for hours to see if you're stable....normal use will tell you too.Best bet would be to set a lower multiplier. The point of the video is not to give a recipe but to show you what you have in the BIOS to tweak. Each CPU will be different and some may not OC to 48 happily.....try 4.7....4.6
Also the BSOD may be related to RAM or power problems...drivers not just the OC. look in event viewer for clues.
10-01-2012 04:27 AM
jblanc03 wrote:
I should be able to be Happy with 4.8 GHZ using this Processor. There must be a setting that i have to tweak a bit.
09-30-2012 11:23 PM
SUKARA@ASUS wrote:
What's the motherboard bios version are you using?
Did you have upgrade the motherbaord latest version?
And
What's model motherboard are you using?
09-30-2012 11:18 PM
10-01-2012 03:26 AM
10-01-2012 05:13 AM
3 Power Supplys: 2x Silver Stone ST 1500w 1x Thermaltake 800w
1 power supply for each thing: 1 for CPU/Motherboard 1 for GPUs and 1 for All watercooling components and controllers:
10-01-2012 10:32 AM
