I have plugged in the cpu fan (2fans of the h100) onto the motherboard (maximus V Formula) since they were connected to the case and I took care of them manually from the switch. The problem is when they are connected to pins cpu and cpu opt the fans are stuck at 100% even when the speed was set manually from the bios they still ran at 100%. AI Suite says this fan's speed cannot be controlled. Is there a fix for this or maybe the motherboard is faulty ??
| Maximus V Formula | i7-3770k | 16Gb Dominator Platinum | GTX 780 | Force 240Gb | 2TB Caviar Green | Obsidian 650D | AX850 | H100 | 24" LED VS247H |
