MIVE-Z: problem to run Kingston HyperX H20 @ 2133 Mhz / 4x4 - please help!!
ROG-Nautilus
Hello,
i can`t run the RAM (4x4 GiB) via X.M.P. @ 2133 Mhz. I have a 2500K without OC at this moment. Bios Version: 3203
i can only run @ 1866 Mhz ... what can i do? 😞
51 REPLIES 51
ROG-Nautilus wrote:
Okay 1866 is enough for me. I have reach 5 Ghz @ 1,45v :cool: with high end watercooling. Is this okay for 24/7?
Have you tried lowering your vcore,and what is your stability like,you may be able to lower your vcore a bit by lowering your PLL voltage,which in turn will lower temps,so it all boils down to what you would consider safe for 24/7 use,and temps.
Had a feeling your IMC was'nt happy with ram at 2133mhz,but 1866 is good,you wont even notice the difference.Well done on sorting it out.
ASUS CROSSHAIR V FORMULA-Z
AMD FX 8350 (1252)
INTEL CORE I7 2600K (3134A867)
ASUS MAXIMUS IV EXTREME-Z (0002)
OCZ VERTEX 3 120 SSD
GIGABYTE 890FXA UD7 REV 2.1 (F3)
GIGABYTE 890FXA UD7 REV 2.0 (F3)
VARIOUS AMD CPU's
8 GIG G-SKILL SNIPER LOW VOLTAGE 1600
4 GIG G-SKILL RIPJAWS X 2133 C9
8 GIG CORSAIR VENGEANCE 1600 C8 (HYNIX)
CORSAIR OBSIDIAN 800D
CORSAIR HX1000W PSU
2X RADEON HD6970'S XFIRE
4X SAMSUNG F3 1T HDD's 2X RAID 0
CUSTOM WATERCOOLING
ROG-Nautilus
You mean when i lowered my PLL Voltage i can get lower Vcore? i have test 1 hour prime95 and then 4 hours BF3 and 2 hour NFS hot pursuit and 1 hour 3D Mark vantage. i think its stable. Look @ my profile i think it`s enough of cooling all 🙂 . in my room is about 27 C. idle temp ~32 C. in Bf3 max. 55 C. load. Prime max. 69 C. (3rd core)
1.79375 is PLL Voltage
1,46V is set to vcore (1,456V in CPU-Z and Mainboard)
What version of P95 are you using,and does it have the latest AVX instructions,better to run custom blend with about 90% of available ram,that's a good stability marker.
AMD FX 8350 (1252)
VARIOUS AMD CPU's
CORSAIR HX1000W PSU
CUSTOM WATERCOOLING
ROG-Nautilus
i use v27.7 build 2. okay then i will test with 90 percent of ram using ...
i have set the RAM to 90 percent @ 14745 MB, but i only get 38% in windows gadget??
ROG-Nautilus
it runs and runs and runs, how long must i run? 😄
*edit* it runs, it runs ...
ROG-Nautilus
Now i have stop it without errors
Wwll done mate,glad your sorted.
AMD FX 8350 (1252)
VARIOUS AMD CPU's
CORSAIR HX1000W PSU
CUSTOM WATERCOOLING
HiVizMan
Level 40
Very good to hear and big thank you to Moorhen2 for stepping up to bat.
Cheers.
Cheers.
No need to thank me mate, but thanks anyway,i try to help when i can,and i do enjoy this forum a lot...:o An old man with too much time on his hands..LOL!!!!
AMD FX 8350 (1252)
VARIOUS AMD CPU's
CORSAIR HX1000W PSU
CUSTOM WATERCOOLING
ROG-Nautilus
Thank you so much 😉
