MIVE-Z: problem to run Kingston HyperX H20 @ 2133 Mhz / 4x4 - please help!!
ROG-Nautilus
Hello,
i can`t run the RAM (4x4 GiB) via X.M.P. @ 2133 Mhz. I have a 2500K without OC at this moment. Bios Version: 3203
i can only run @ 1866 Mhz ... what can i do? 😞
51 REPLIES 51
Jim-M4EZ
... in Extreme Tweaker, what is Memory Bandwidth Booster set to : Enabled / Disabled ...
I have to "disable" MBB to run my Redline 2133 in XMP ...
... hth ...
- M4EZ - 1: 3510 - 2: 1004 / i7-2600K / Redline 2133 16GB / Win7 Pro x64
- v.3510 / 8.0.0.1351 - v.8.1.0.1263 / 10.8.0.1303 - v.11.2.0.1006
- RevoDrive3x2 240GB - OS / Vector 256GB x2 RAID0 - OS / Vertex3 MI 120GB - OS / P'9230 3.0 2TB - B/U
- 9260-8i BBU - CacheCade Pro Vertex3 120GBx2 RAID0 SSD Caching - Const ES SAS RAID10 GHS - Data
- GTX580 3GB HC2 / Xonar Essence STX / ST1200G / TJ10B-W / ZR30w / SP 2500 2.1
- Water: Swiftech/Koolance/Tygon/EVGA/MIPS - Wind: SST/Noctua/Cougar
I have MBB disabled ... any other idea?
Sorry that didn't work for you ...
... assume you've already run memtest ...
HiVizMan
Level 40
Which of the two profiles are you using?
I would think you are on profile 1 which is very aggressive Cas9 please try profile 2.
http://www.kingston.com/datasheets/KHX2133C11D3W1K2_8GX.pdf
XMP TIMING PARAMETERS
• JEDEC: DDR3-1333 CL9-9-9 @1.5V
• XMP Profile #1: D3-2133 CL11-12-11 @1.60V
• XMP Profile #2: D3-1600 CL9-9-9 @1.5V
HiVizMan
Level 40
That is odd as my set have the more aggressive timing as profile 1.
Thanks for the heads up
... looks like "something" in the bios is hanging it up at 1866 - should run at 2133 ...
Might want to consider re-setting bios to factory defaults ...
... & then re-set up from scratch - trying to clear out / eliminate the proverbial "something" setting ...
i use this ones -> http://www.kingston.com/datasheets/KHX2133C10D3W1K2_8GX.pdf
i can only set to XMP Profil 1 = 1866 Mhz working fine
with XMP Profil 2 = 2133 Mhz i cannot run machine
Well, that certainly explains the 1866 speed ... 😮
... good to see one of the profiles working to spec.
