Memory problems w/ M6 Extreme - XMP setting
LaserPete
I'm getting freezes, lockups, BSOD's and corruptions of Windows 7 OS when using XMP settings with default BIOS settings.
Memory is G-Skill F3-2133C11Q-32GZL. 32-GB kit - 4X8GB. XMP frequency is 2133 Mhz.
BIOS is 1302.
Memory was tested w/ Memtest 86+ ver 5. Each stick for 3 full cycles at 2133 Mhz passed. Using slot A2.
Memory was also tested with OCCT for 5 minutes with no errors. All four sticks together.
The bad things will start happening around 30 minutes after using the XMP profile or when its warmed up.
Same bad things if memory Volts, Freq and Timings are set manually using the XMP setting information.
BIOS is at the "Default Optimized" settings except for XMP and the graphic card PCIe settings.
Window 7 is in Performance mode (%100-%100) with no power saving features enabled.
CPU is running at a steady 3900 Mhz.
No problems running with Auto at 1333 Mhz but thats kind of slow.
Also,
BIOS locks up at Q-code "15" after the power supply is first turned on. After warming up it will get past Q-code "15".
No problems getting past "15", if the memory is set manually for Volts, Freq and Timings.
After weeks of repairing the OS over and over I have now become good friends with ChkDsk /f.
The reasons why I bought this memory:
Its on the QVL list.
32-GB for possible future uses, like a RAM disk or video editting.
Low 1.5 volt to help out with heat on the processors Uncore.
Frequency should be enough for my target OC of 4.2 Ghz.
I have screen shots of the BIOS settings if needed. What size, BMP or JPG and do I use "attachments"?
Any help would be appreciated.
Thanks,
Pete
ASUS Maximus VI Extreme
Intel i7-4770K
G-Skill 4X8 GB 2133 MHz C11
Samsung 840 Pro 256GB - X2
WD 1TB Black
EVGA GTX-780 Ti SC w/ACX
EVGA SuperNOVA 1000 P2 PS
Corsair H110 cooler
Corsair 650D case
Windows 7 Pro 64
20 REPLIES 20
COLDSTATIC
I just went and took a bunch of screen shots of my bios.
Tried to get images to post but i kept doing something wrong. here is a link to gdrive folder. https://drive.google.com/folderview?id=0B0VDO3rn0zlgWkkxVzV3Z3htaFk&usp=sharing
I also thought of a good way to think of the volts on Sat ioa iod. Don't think of being higher or lower due to speed or anything. Think of the volts as being in or out of focus with binoculars. If your looking at something close (2133) but have it focused far ( as .250) then it looks like crap.
4770k | Asus Hero | G.Skill Trident 2400 32gb | Samsung 840 pro 256gb
NZXT Kraken x60 | Asus GTX780 Direct CU ii OC | Razer tiamat 7.1
Razer Imperator | Razer Nostromo | Antec High current pro 850
Thermaltake Xaser Vi | Windows 8.1 64bit
