MediaTek Wi-Fi 6E MT7922 (RZ616) 160MHz Wireless LAN Card : Has determined that the network adapter
sebsand
Build specs:
ASUS ROG STRIX X670E-A GAMING WIFI
AMD RYZEN 9 7900X
NVIDIA 4070TI
CORSAIR VENGENCE 2 X 32GB RAM
CORSAIR RM1000X 1000W PSU
Just built a new PC and all seemed fine for a few days but now I keep getting this error message in event viewer:
Event ID 5002
Source: mtkwlex
The WIFI cuts out every 10-30 minutes and sometimes it will have a good stint of up to an hour.
Also getting this warning:
Intel(R) Ethernet Controller (3) I225-V
Network link is disconnected.
Event ID 27
Source: e2fnexpress
I don't know if it is related but my PC has been randomly glitching and freezing, wifi cuts out and the rgb returns to standby settings and then eventually PC restarts. Error for that is is kernel power 41.
I have tried a number of things including updating drivers, rolling back drivers, updating bios, running in safe mode, reconfigured fans, unplugged everything, swapped RAM around.
When everything is working there are no issues with performance or temperature.
BASICALLY HELP?
kharakdar
bonjour,
j'ai eu le même problème, que j'ai résolu.
J'ai mis à jour le pilote de la carte wifi.
Le problème est une erreur du port de la carte wifi, qui ne s'actualise pas, j'ai donc laissé l'ordinateur allumé sans l'adaptateur secteur jusqu'à vider la batterie...
cela a fait un hard reset de la carte mère.
