06-28-2013
09:58 AM
- last edited on
03-06-2024
08:44 PM
by
ROGBot
06-28-2013 10:23 AM
06-28-2013 10:37 AM
06-28-2013 11:29 AM
passionne wrote:
Hello,
I encounter 2 problems with the Hero motherboard :
1. The CPU frequence does not remain at the overclocked frequency : if the application is not too intensive (Hyper Pi, WORD, Excel...), the frequency changes constantly from 3400 Mhz to 4800 Mhz. I disabled C-states, Speedstep, but Turbo is enabled. I assume that Turbo is responsible for this phenomenon but if I disable it, I cannot overclock anymore.
2. Yesterday, I installed Windows 7 from a USB3 key and the installation took 1 hour instead of 10 minutes on other motherboards, with the same USB key (ADATA S102 16 GB) and the same SSD. The USB3 key was plugged in one of the blue USB plugs located on the rear motherboard panel. Then I tried on a USB2 plug and the speed seemed as slow as the USB3 connector. I tested my USB key with Crystaldsikinfo and My read results are as expected. My writes are lower than expected but they are not likely to be the cause because I assume that installing Windows consists of reads only. Then, today, I plugged the ADATA key again into a USB3 plug, booted, launcned the Windows 7 installation and the beginning was very fast, even faster than ever (when the screen is black and "Windows is loading files" is displayed) but when the language is requested, the screen was frozen.
Any ideas concerning these 2 problems ?
06-28-2013 01:40 PM
passionne wrote:
When I launch HyperPi, the CPU works onlu at 2 - 3 % instead of 100 %. I don't know the reason.
