Maximus VI Extreme CPU Opt Fan
Joice79
i have a problem. I have attached my cooler first pwm fan to cpu fan and its work, i have attached the second cooler pwm fan to the cpu opt, but it is not releaved in the bios. Why? And how to solve?
thanks
15 REPLIES 15
Nate152
Hi joice79, Welcome to the ROG community. Can I ask what cpu cooler you are using?
Chino
Level 15
Chino wrote:
The settings for the CPU_OPT header is tied to the CPU_FAN header.
Hi, can you explain me better? In the bios i have the "Cpu Optional" under Fan Control but no there's the rpm ....
http://imageshack.com/a/img802/2796/7r13.png
http://imageshack.com/a/img845/7179/rtan.png
The cooler is Be-Quiet Dark Rock Pro 3.
Does that fan that is connected to the CPU_OPT header spin?
haihane
can you unplug the fan in question from CPU_OPT and plug it into other headers in the motherboard and see if the rpm shows up?
CHA_FAN is fine too. just for testing purposes
no siggy, saw stuff that made me sad.
Joice79
las week i have tested a hero vi mb, with other pwm fan but same issue.... In your one it's work?
Joice79
Hi, it is connect here
http://imageshack.com/a/img34/1511/ku1d.png
With the hero same problem with other brand pwm fans.
Chino
Level 15
Joice79
The fan work but why i can't see in bios? On the hero too.
