Maximus V Formula Thermaltake Armor Revo fan issue with AI Suit
RCNitro13
My Thermaltake Armor revo came with 4 fans, front, top, side (which is plug and play) and rear. The front, top and side fans were cabled together so all I had to do was connect the power and they all worked. Having it this way, the case LED on/off and fan high/low buttons also worked.
The rear fan wasnt cabled with the rest so I connected it onto a spare fan slot onto the MB.
With the above, AI Suit picked up the CPU and rear fan but not the other so I decided to cable each fan individually onto the MB, this is where my issue starts.
Having all the fans connected onto the MB OPT or CHS fan slots, they all work but now I cannot use the case LED on/off button (LED's are always on now) and speed high/low buttons, that's OK, I wanted to use Fan Xpert.
But now Fan Xpert doesnt pick up all the fans, its picked up CPU (which was always there), but now I have 2 x rear fans, one is editable and the other is grey out.
Ive enabled all the fans in the BIOS.
I tried to auto detect the fans but that didnt help.
How can I get Fan Xpert to pick up all the fans?
I'll probably have to go on Thermaltake forum to see if I can cable the LED and fan speed cables unless someone here has the same??
Thanks!
RCNitro13
Forgot to mention, all fans are 3 pin if that helps.
