Maximus V Formula sudden power-off issues
jadecristal
So, I put together a Maximus V Formula (AC3) system, with specs as follows:
Antec HCP-750 power supply
Intel i5-3570K, with retail heat sink + AS5 thermal material
Corsair 16GB 4x4 CML16GX3M4X1600C8 RAM (from the MVF QVL)
EVGA GeForce 560Ti FPB video card
I don't think the two hard drives, single SSD, or single optical drive matter for this.
After assembly, I flashed the UEFI BIOS to 1604 and put Win8 on it, and installed drivers. No AI Suite ever got installed, or any other of the special ASUS software for charging, etc.
Everything ran nice for a few weeks, plus or minus - after everything got installed, uptime was at least 16-some days. Then I came home one night to find it off. Over the next day, it suddenly shut off with a "click" sound with no warning a few more times, until I just gave up on it being a random glitch.
I read about the Q-Fan issues some people are having, but that doesn't seem to be the potential problem here. Currently, it will still suddenly shut down randomly - even after a short period of time - after just starting up and entering the BIOS. However, it also ran MemTest for 28-ish hours, with no errors or restarts, a few days ago (booted from a USB key).
Thoughts? I'm kinda at a loss here.
-jadecristal
8 REPLIES 8
nikosa43
Level 12
''it suddenly shut off with a "click" sound''
Hi there, welcome to ASUS ROG.
Is it possible for you to find another PSU and give it a try?
It's the first thing that came up to my mind, as I read your post.
I have another HCP-750 NIB, but... it seems odd. After running for a couple weeks. I could, though.
I second the PSU theory.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
Zka17
Level 16
Yeap, my first step would be also to check the PSU...
The second, to check if there are any shorts in your setup... and/or maybe something came loose, some connectors... - actually I would try to trigger that symptom by gently moving the case while the pc is on... but, first, be sure that your PSU is OK
red454
Level 11
In the electrical short direction, could there be an extra (unnecessary) stand off under the motherboard?
ASUS Rampage V Extreme BIOS 4101 | i7-6950X | Thermaltake Core X9 | G.Skill F4-2800C16Q-32GRK | Cooler Master Nepton 280L | Dual Samsung 850EVO 500GB SSD | PSU: DARK POWER PRO 11 1000W | 3TB & 4TB HDD | NVIDIA GTX Titan X | ASUS 24x DVD±RW Drive | Win10 Pro
freeleacher
Im having the exact same problem exact same board.
Just powers off without warning,
Bran new power supply enermax 80+ gold 650 watt.
Its happened to me now several times and all im doing at the time is watching video.
nikosa43
Level 12
Unfortunately the guy started the thread didn't give any feedback. Sudden shut downs for me usually comes from Power supply or overheated CPU or Graphics card. Check your fans/temperatures to both CPU and GPU and if possible check your system with another Power supply.
HiVizMan
Level 40
Quite correct it does sound like a heat thing. Freeleecher could I ask that you start your own thread and list all your hardware please.
