Maximus IV GENE-Z BIOS Guide - Overclocking
Raja
The Maximus IV Gene-Z is the smaller sibling to the flagship Maximus IV Extreme and Maximus IV Extreme-Z motherboards. Many of the overclocking features found on the bigger siblings make their way onto the Gene-Z.
We’ve also managed to provide you with a 250 amp capable VRM on the Gene-Z to supply CPU Vcore. That means the Gene-Z should be capable of keeping up with its full sized ATX counterparts when it comes to processor overclocking!
We’re going to walk you through key BIOS overclocking features and break down their usage, to help you get the most from this exciting little motherboard.
Upon entering UEFI BIOS, we navigate to the AI Tweaker menu:
1274
CPU Level Up: Allows us to select a pre-set profile that contains voltage and bus adjustments to apply a mild overclock to the system. Use this setting if you do not wish to overclock the system manually.
Load Extreme OC Profile: For extreme overclocking only. Contains a pre-set that sets all processor and system current thresholds to maximum – in order to facilitate quick setup when overclocking the processor under sub-zero cooling.
Ai Overclock Tuner: Options are Auto, Manual and X.M.P.
Auto: This is the default setting, and needs to be changed to Manual if you wish to change BCLK (BCLK is the base reference frequency from which processor and other system bus frequencies are derived).
X.M.P: Extreme memory profile, use this option if you have Sandy Bridge qualified XMP memory. X.M.P. profiles contain pre-sets for system buses and in some cases voltages. If the specified speed of the DIMMs is greater than the supported memory frequency of the platform, a platform specific X.M.P. profile option becomes mandatory because processor core and memory controller voltage requirements vary from architecture to architecture. High-speed enthusiast memory kits manufactured before the inception of the Sandybridge platform may not contain the necessary/adequate voltage offset settings for the system to be completely stable. In such instances, manual adjustments of memory controller voltage and memory timings may be necessary.
Selecting the X.M.P setting opens up options for X.M.P profile selection (the kit may contain more than one X.M.P profile), and also opens up the BCLK option for changing system bus frequency. Note that memory operating frequency and maximum CPU operating frequency are shown towards the top of the Ai Tweaker menu, while memory timings and voltage are displayed next to the XMP profile selection box.
BCLK/PCIe Frequency: This function becomes available if X.M.P or Ai Overclock Tuner “Manual” are selected. The base BCLK frequency is 100MHz. As the name implies, changing the BCLK frequency will also change PCIe frequency. The maximum CPU core frequency is derived via multiplication with the Turbo Ratio setting (final frequency is displayed at the top-left of the Ai Tweaker menu).
Bear in mind that the adjustment margin for this setting is not large - most processors have a range from 95~107 MHz. Changes to BCLK and stable operation of high memory frequencies (DDR3-2133+ for example) may benefit from manipulation of clock skew settings (more on that subject later in the guide).
Turbo Ratio: Options are “Auto”, “By All Cores” and “By Per Core”. A description of these settings is provided in the right-hand column of the UEFI BIOS and can be seen when the Turbo Ratio setting is selected.
By All Cores: This sets the CPU core frequency multiplier; multiplied by BCLK to give the target CPU frequency (under full load conditions if SpeedStep is active). “Auto”: Stock CPU multiplier Ratio used. Manual numerical entry of the desired Turbo Ratio is accepted.
Per Core
: Allows setting the maximum Turbo multiplier of each physical processor core.
The available multiplier range is limited by both processor model and the ability of each CPU.
Internal PLL Overvoltage:
Options are “Auto”, “Disabled” and “Enabled”. A manual setting of “Disabled” is recommended within the bounds of moderate overclocking. Using Core frequency multipliers in excess of 45X may need a setting of “Enabled”. The requirements of the “Enabled” setting will vary from processor to processor. The unfortunate side-effect is that resume from S3 sleep states is not possible when Internal PLL Overvoltage is set to “Enabled” - this is a hardware limitation, and only fixable by Intel.
Memory Frequency: “
Autowill automatically select a memory multiplier ratio according to memory module SPD (Serial Presence Detect). Manual selection of the available memory frequency multiplier ratios is possible and works according to the abilities of the DRAM and processor. Granular control of memory frequency is available by manipulating BCLK (within functional limits).
Memory Bandwidth Booster
: Uses a tighter set of memory timings for benchmarking purposes. Use only with enthusiast oriented memory kits. Keep disabled when using 4GB DIMMs or when gunning for maximum memory frequency.
iGPU Max Frequency: Sets the maximum iGPU frequency in 50MHz steps (implied).
EPU Power Saving Mode
: When “Enabled” is selected, utilizes power phase management based upon system loading to reduce system power consumption. A setting of “Disabled” is recommended for heavy overclocking.
104 REPLIES 104
ok, so I just tried that but again the systems crashed... any other advice?
Hello Lannister.
First Id download memtest and put on a cd/dvd then boot from the dvd/cd.
Test out the ram is what it will do........if any errors are reported. (Maybe a bad sticK.)
Did it always do this?
Also test the video card........stock settings once again........from what your describing, it could be a overheating vid card.
You say the games blue screen...........do you play for a few moments? then blue screen?
Do you get a dump file? what does is say...?
Or check for Events.......go start and type Event. See if there is anything reported there......if so copy it and some how get it to Rajas for a look......any error codes on the mobo itself?
I wish you best of luck Lannister........I to just had a vid card 4ish years old....start acting funny........my screen would go black and the computer would still be going strong............weird I know but can happen. It did to me.
Also you could pull the video card and use the onboard.........just to see if that clears it all up..... if so you know whats what.
Good Luck Lannister.......try memtest on the ram......and pull the vid card go to onboard.... just to see.
Keep the shinny side up.
hey gore, thanks for your help...
so i am running memtest at the moment -not the bootable cd but from windows, is that less reliable?
anyways, it's at 170% now and hasn't found any errors so far.
the problem always occurs in specific tasked - for example opening the map in skyrin. just playing the game works fine - most of the time. in other games there are also specific triggers that lead to the pc crashing down or freezing up. and interestingly changing bois settings like vcore, ppl and so on does effect the game. so right now i am at the point that changing other setting will only make the crash come sooner but there seems not to be a possibility to make it run stable.
as for trying to use the onboard video card, well, since it only really happens when playing modern games, i doubt that the onboard would even be able to load the game (even with lowest settings) - i could try looking for an really old game that would run with a disabled graphics card and then look for a way to trigger the crash, but that'd take ages...
furthermore, i looked into the event recording you mentioned and i do find the crash downs but it doesn't really state the reason for them. just says : source: kernel-power; event id: 41; level: critical
digmeahole
sticky! Sticky!
"Those who are willing to give up freedom for security deserve neither"
Ben Franklin
Asus Maximus IV Extreme Z
Intel I7-2700K OC to 4.7 @ 1.330 volts
2X EVGA 660TI SLI
G.Skill Ripjaws Z 2133Mhz
2x Samsung 840 Pro 256GB SSD. Raid 0. 1 500gb WD VelociRaptor
Antec Gamers edition Bronze rated PSU 750 Watts
Corsair H80 Closed loop CPU cooler
Dragon Test Bench Case
@Grnfinger
You can achieve much more with this board. 😛
I bet it can do even more....
Nice Oc`s this mobo is the bee-z Knez.
I have not Ibt or primed this OC yet....
Im still working on the cooling end of things. (Soon)
Nothing Micro about this Micro ATX.
5283
Just wanna say how impressed I am with this little board. I bought mine just beofre Xmas as I couldnt find a local Gen 3 board.
Not too bothered about PCI ex3 as when i next upgrade my gfx card i'll be doing the lot.
2500k sitting happily on 4.6ghz turbo mode but more than happy to idle at 1.6ghz. Voltage capped at 1.29 and I dont see above 54 degrees Core temp but thats down to my custom Water loop i'd say.
With my GXT480 Hydro it rattles through BF3 at 1920x1080 everything on Ultra at over 40fps. If i turn down AA slightly it goes over 60fps. AWESOME
My only issue is the time it takes to POST but once it gets past that my SSD takes over and i've recorded a best time of 7s on bootracer (64 bit Win 7). I am one happy boy!!!
Gore
Hello Lannister.
Im happy to hear your ram is passing..........either windows or dvd/cd bootable....if you pass you pass........so ram is not it. whew...save $$$*
You have a very Generic error code.....41 windows event...unlucky you.
Here are some links to possible remedies.
http://www.overclockers.com/forums/showthread.php?t=677174 -- This person has same exact issue.
http://support.microsoft.com/kb/2028504 -- what Microsoft has to say.....no help there.
At the end of the day you have a power issue............lack of................
What Power Supply are you using..........? is it enough?....hope your not running a 550w with little amps? As the PSU will trip and reset?
I would still save the Dump...or the Event my that sounds awful Dump Event.....lol
Post it here and see if Rajas will be kind enough to take a few secs to look...........
does the machine stay on after Bsod........or does screen just go black and computer stays on....no sure....or does it just hang a bsod and sits?
Sounds funny my questions but need to know Lannister.
Do you have Virtua Lucid on?...........turn it off.............see then if it stops.......
I know Im asking for alot but try these things.........and id still try pulling the vid card and go on Die....just to see if it still craps out or forges on ahead........even with a old game..............try my friend.....
So give these things a go one by one.........and stock bios settings...no oc anything.....regular auto all.......then we start later to turn things back up.......but we are not at that point yet......lets eliminate the ram and vid card also powers supply are suspects first.......I rather not up volts for anything yet...Just upping the volts is not the great savior all think....
I will check back........like to see the dump and the event so post em.........someone will have a easy answer? or lead you to Glory and Stability.
Best of Luck Lannister. :cool:
well, actually my psu is a 500w sharkoon rush power - but i always though i did my homework before deciding on which components to buy and i read quite often that 500w should be sufficient for this machine...
and for the crashing itself. it's not always an acutal bsod. often the screen just goes black and the pc starts making an awful sound and then restarts... or i restart it manually. i am gonna check that again...
cheers
Grnfinger
20 amps on each rail. Unless the PSU is failing I would say its fine for his rig.
I ran Crossfire 6870's on a H620 With a 920 overclocked to 4300. No issues at all, it even ran my 5970 (barely)
4770K@4500mhZ
Asus Maximus VI Hero
2x Sapphire Tahiti core 7870 Crossfire @ 1150/1500
8GB Patriot Viper @ 1866MHz
Intel 520 SSD - 2x1TB Raid0 - 2TB WD Green
Corsair AX860i
Cosmos S Custom
H20 Cooling
