DRAM Timing Control: Takes us to the DRAM timing sub-menu, where all primary, secondary and tertiary memory timings can be set:
Mem-Tweakit Support: Can be left Enabled at all times. This setting allows manipulation of DRAM timings from the operating system in real-time using the ASUS Mem-Tweakit software.
Memory timings will automatically be offset according to memory module SPD and memory frequency. Should you wish to make manual adjustments, the primary settings are the most important for overall memory performance. Most timings are set in DRAM clock cycles, hence a lower value results in a more aggressive setting (unless otherwise stated).
As always, performance increases from memory tuning are marginal and are generally only noticeable during synthetic benchmarks. Either way, voltage adjustments to VDIMM, VCCIO and to a lesser extent CPU Core Voltage may be necessary to facilitate tighter timings.
Primary Timings CAS: Column Address Strobe, defines the time it takes for data to be ready for burst after a read command is issued. As CAS factors in almost every read transaction, it is considered to be the most important timing in relation to memory read performance.
To calculate the actual time period denoted by the number of clock cycles set for CAS we can use the following formula:
tCAS in Nano seconds=(CAS*2000)/Memory Frequency
This same formula can be applied to all memory timings that are set in DRAM clock cycles.
DRAM RAS TO CAS Latency: Also known as tRCD. Defines the time it takes to complete a row access after an activate command is issued to a rank of memory. This timing is of secondary importance behind CAS as memory is divided into rows and columns (each row contains 1024 column addresses). Once a row has been accessed, multiple CAS requests can be sent to the row the read or write data. While a row is “open” it is referred to as an open page. Up to eight pages can be open at any one time on a rank (a rank is one side of a memory module) of memory.
DRAM RAS# PRE Time: Also known as tRP.Defines the number of DRAM clock cycles it takes to precharge a row after a page close command is issued in preparation for the next row access to the same physical bank. As multiple pages can be open on a rank before a page close command is issued the impact of tRP towards memory performance is not as prevalent as CAS or tRCD - although the impact does increase if multiple page open and close requests are sent to the same memory IC and to a lesser extent rank (there are 8 physical ICs per rank and only one page can be open per IC at a time, making up the total of 8 open pages per rank simultaneously).
DRAM RAS Active Time: Also known as tRAS. This setting defines the number of DRAM cycles that elapse before a precharge command can be issued. The minimum clock cycles tRAS should be set to is the sum of CAS+tRCD+tRTP.
DRAM Command Mode: Also known as Command Rate. Specifies the number of DRAM clock cycles that elapse between issuing commands to the DIMMs after a chip select. The impact of Command Rate on performance can vary. For example, if most of the data requested by the CPU is in the same row, the impact of Command Rate becomes negligible. If however the banks in a rank have no open pages, and multiple banks need to be opened on that rank or across ranks, the impact of Command Rate increases.
Most DRAM module densities will operate fine with a 1N Command Rate. Memory modules containing older DRAM IC types may however need a 2N Command Rate.
Secondary Timings DRAM RAS to RAS Delay:Also known as tRRD (activate to activate delay). Specifiesthe number of DRAM clock cycles between consecutive Activate (ACT) commands to different banks of memory on the same physical rank. The minimum spacing allowed at the chipset level is 4 DRAM clocks.
DRAM Ref Cycle Time: Also known as tRFC. Specifies the number of DRAM clocks that must elapse before a command can be issued to the DIMMs after a DRAM cell refresh.
DRAM Refresh Interval: Also known as tREFI. Specifies the period that must elapse in DRAM clocks before a refresh command is issued. A larger value here is actually more aggressive as it increases the delay between refreshes. The charge stored in DRAM cells diminishes over time and must be refreshed to ensure that data is not lost. The minimum interval between refreshes varies according to DRAM ICs and the density of the modules – higher density module generally need refreshing more often (lower value for tREFI). Refresh interval requirements also tend to vary according to DRAM temperature (changes in cell leakage rates) and VDIMM, so be prepared to experiment with values if sub-zero cooling is used on memory.
DRAM Write Recovery Time: Defines the number of clock cycles that must elapse between a memory write operation and a precharge command. Most DRAM configurations will operate with a setting of 10 clocks up to DDR3-1866. After that, relaxing to 12+ clocks may be necessary at DDR3-2000+. High performance PSC type DIMMs can use a tWR of 8 at speeds over DDR3-2300 (memory controller permitting).
DRAM Read to Precharge Time: Also known as tRTP. Specifies the spacing between the issuing of a read command and tRP (precharge) when a read is followed by a page close request. The minimum possible spacing is limited by DDR3 burst length which is 4 DRAM clocks. Most 2GB memory modules will operate fine with a setting of 4~6 clocks up to speeds of DDR3-2000 (depending upon the number of DIMMs used in tandem). High performance 4GB DIMMs (DDR3-2000+) can handle a setting of 4 clocks provided you are running 8GB of memory in total and that the processor memory controller is capable. If running more than 8GB expect to relax tRTP as memory frequency is increased.
DRAM Four Activate Window: Also known as tFAW. This timing specifies the number of DRAM clocks that must elapse before more than four Activate commands can be sent to the same rank. The minimum spacing is tRRD*4, and since we know that the minimum value of tRRD is 4 clocks, we know that the minimum value for tFAW at the chipset level is 16 DRAM clocks.
As the effects of tFAW spacing are only realised after four Activates to the same DIMM, the overall performance impact of tFAW is not large, however, benchmarks like Super Pi 32m can benefit by setting tFAW to the minimum possible value.
As with tRRD, setting tFAW below its lowest possible value will result in the memory controller reverting to the lowest possible value (16 DRAM clocks).
DRAM Write to Read Delay: Also known as tWTR. Sets the number of DRAM clocks to wait before issuing a read command after a write command. The minimum spacing is 4 clocks. As with tRTP this value may need to be increased according to memory density and memory frequency.
DRAM CKE Minimum Pulse Width: Also known as tCKE. Specifies the minimum time in DRAM clock cycles the DRAM stays in self-refresh mode (low power state) or in clock enabled state (normal operation) before assertion or de-assertion. Toggling of CKE is initiated with C-States and DRAM power saving modes active only and can safely be left at default value for all operating conditions.
