07-02-2012 03:14 AM - last edited on 03-06-2024 08:16 PM by ROGBot
07-05-2012 01:25 AM
07-05-2012 01:30 AM
07-05-2012 02:34 AM
07-05-2012 07:49 AM
07-05-2012 08:36 AM
07-05-2012 11:47 AM
07-05-2012 12:08 PM
HiVizMan wrote:
OK thank you.
Let me try and describe what I think you are experiencing. If you were to put a stick of ram in the first two slots (closest to the CPU) your system will return the post code 55. If you place a stick of ram into the furtherest two slots your system will post.
Can you confirm this.
07-05-2012 12:31 PM
07-05-2012 12:51 PM
HiVizMan wrote:
If it is a simple process to remove your cooler and reseat your CPU we can try the following.
Remove all from your system, CPU the works even the battery.
Clear CMOS let your system stand over night.
Reseat the CPU and mount your cooler.
One stick of ram furtherest slot from CPU.
No HDD
One VGA if you are using one.
Keyboard and mouse.
12Volt CPU connector.
24pin PSU power connector.
Power up.
In BIOS set XMP
Advanced memory settings ---> disable the quick training function.
Manually set your voltage for the DDR3 ram.
F10 to save and press enter.
Del to enter BIOS and then power down.
Add one additional stick to create a dual channel configuration.
Power on.
Report back if you are successful.
07-05-2012 12:53 PM
