11-25-2011 02:11 AM - last edited on 03-06-2024 01:23 AM by ROGBot
01-17-2012 04:10 PM
01-19-2012 04:21 AM
Grymmie wrote:
Can't tell you 'why' this happens, but it appears to be related to ACPI standby modes and/or hibenation. I can always tell I have that darm USB error, when my boot time on the UEFI logo adds any extra 10 to 15 seconds. By cutting off power to the motherboard for at least 1 minutes, the problem seems to clear.
Regards,
01-20-2012 12:04 PM
01-20-2012 05:11 PM
01-20-2012 11:27 PM
01-21-2012 04:16 PM
01-21-2012 04:21 PM
01-29-2012 10:51 AM
KILLFIREX wrote:
I have the Asus Maximus IV Extreme-z (Z68) and I have having the exact same issues, I followed what ROG1 stated, and the issue was resolved for me, quick and easy fix!
02-19-2012 03:35 AM
02-26-2012 05:04 AM
RenesisR wrote:
I tried that fix, it does not work for everyone. I have finally found the culprit and the solution to this. Your USB3.0 port will fail to work whenever the device you connected to is drawing too much power (eg. you are using it as multiple hub connecting to more than one USB device)
You need to download the lastest Renesa USB3.0 driver 2.1.28.0 which would inform you to reset the USB 3.0 port for it to continue working or u will get the unknown device error.
If installing the new driver does not work for you, then you need to perform the below:
1) Connect your keyboard and mouse to a USB 2.0 port (should be your front port or your optional port)
2) Remove all devices connected to your USB 3.0 ports
3) Uninstall the USB 3.0 driver but do not delete it
4) Shut down your PC and press the Clear CMOS button for 10 sec at the back of your mother board
5) Restart your PC and your USB 3.0 drivers should install itself at startup
6) Make sure that you do not over exceed the USB 3.0 port supported power supply, but if you do driver 2.1.28.0 will inform you 😄
7) Let me know if it works for you
Thanks
