Hi all, I'm hoping someone can provide me some recommendations for my next testing steps. I have an Asus Maximus IV Extreme motherboard. I purchased G.SKILL Ripjaws X F3-14900CL9D-8GBXL 8GB 2X4GB DDR3-1866 CL9-10-9-28 Memory for my mobo. Since purchasing this RAM, I've never been able to achieve stability with my board.
I'm running windows 7 64-bit and have a Intel Core i7 2600K CPU. I have never even tried to overclock by any means, just trying to run with stock speeds. The reason I'm posting on this forum is because when setting my RAM speeds in the BIOS I've selected XMP due to recommendations from G-Skill forums, I've specifically ensured the RAM timings are correct, and also I've made sure that my I've specifically set the MHz to 1866.
The reason I'm concerned about stability is that if I use the default BIOS settings it will automatically choose that my RAM is 1600MHz, and also even if I use the XMP profile and manually set 1866MHz, when I view the status pane to look at my video card speed and RAM speeds it says "1600 MHz RAM running at 1866MHz".
Is my RAM not a suitable candidate for this mobo? I've checked the latest published list and my RAM is actually not on the QVL, so that may explain weird BIOS support. And/or are there any other settings that I can tweak to make this function better? At this point, I'm not complaining about speeds, I simply want stability. Every time ASUS has upgraded the BIOS I have updated mine and I'm currently running - BIOS 3211.
Thanks for any help and feedback you can provide.
Neil
