Hi I've being having this issues for ages were my system would be running just fine but the q-led code would display 00 constantly the only time where it wouldn't would be at boot at and when I'm in the bios. I've change motherboard, ram, cpu and hard drives just to try and fix this issue but it always the same regardless of what I try, so I contacted each manufacturer and asked if this was maybe an issue with the CPU since the error code indicates that the CPU in not in use and from what I was told it should not be the CPU fault since it works fine without any issues, so after countless attempts I nailed it down to it being a hard drive issue so what I did I bought a new SSD and did a fresh install of Windows 10 and is seemed to run well because it was finally displaying the Q-led code A0 with indicates that the system is running fine, but then after installing all the updates and starting up the Asus AI Suite 3 and running the fan tune up option it went back to the 00 code and the only way to fix it was to uninstall the whole suite and restart the system and then it would go back to A0. So please If anyone has an idea of what could be causing this issue please let me know.
Thanks.
Bye.
P.S.
My Setup:
Case: NZXT H440 Black & Red
CPU: Intel Core i5 @ 4.6 GHz with 1.3v on adaptive voltage
Mainboard: Maximus VII Hero (BIOS: 3033)
Graphic: Asus GTX 760 OC
SSD: SanDisk Ultra II 480 GB
RAM: 8 x 2GBLP Corsair Vengeance (1600MHz)
PSU: Corsair CM600M
CPU-Cooler: Cooler Master Hyper 212 Evo
