Maximus Hero VI power consumption
ArunKumar
Hello Everyone,
I would like to know what is the total power consumed my my mother board at full load,i.e please assume that i have used up all the RAM slots ,PCI express slots and all the SATA ports and of course mounted a CPU, I checked in the manual but could not find it listed anywhere.
I am planning to buy a UPS for my build so i need to calculate the closest possible total power consumption.
Secondly could someone please tell me the maximum current the USB port could give when i activate the USB charger+ through AI SUITE?
Thanks in advance,
Arun
Motherboard: Asus Maximus V1 Hero Motherboard
CPU: Intel 3.4 GHz LGA1150 4670K
RAM: Corsair Vengeance DDR3 4 GB x 2
HDD: WD Blue WD10EZEX 1 TB Internal Hard Drive x 2
SDD: Samsung 840 Series 120 GB SSD Internal Hard Drive
PSU: Corsair TX 750
CASE: Cooler Master Enforcer Mid Tower Cabinet
CD/DVD drive:HP DVD1260i-UH07D DVD Burner Internal Optical Drive
Keyboard and mouse: Razer blackwidow 2013 & Razer deathadder 2013
6 REPLIES 6
ArunKumar
Any Help please...
PSU: Corsair TX 750
HiVizMan
Level 40
No idea. You are asking us how long is a piece of string. Simple answer is buy your UPS big enough to handle your power supply.
ArunKumar
I emailed ASUS techsupport with this query ,
Here are the details:
Intel single chip platform (PCH) motherboard consumes around 20W and adding the chipset is about 7-8 wats,so rough estimate i can consider it to be around 30 W.
USB3 standard output is 1 Amp.
If USB charger+ is enabled ,the device connected can get a maximum of 2 Amps.
PSU: Corsair TX 750
As far as I understand, you need a power consumption estimate.
38900
My setup consists of:
i7 4770K @ 4.2 Ghz
32 GB RAM (4 x 😎
1 SSD
5 HDD
1 DVD
1 GTX 580
Hero VI
7 air vents (220-80)
My APC 800+ holds this unit, including my 24 Dell for about 30 minutes
Hope this answers your question
Deepcuts
Now you made me curious.
Enabling PCIe power management in BIOS shaved 12-15 W. Now getting 163 W idle.
I think I just found out my new hobby: getting the lowest consumption while overclocking at 4.2 Ghz 🙂
That made me laugh, and it is a very good idea would like to see you have your own thread detailing all the stuff you tried and what the outcome was for each change in settings.
