10-01-2011
06:15 PM
- last edited on
03-06-2024
10:33 PM
by
ROGBot
10-14-2011 08:22 PM
12-12-2011 05:01 PM
RagingCain wrote:
Only have a set of G.Skill Tridents to play with at the moment, but can anyone suggest anything?
Can't post no matter what I try. I assume this is memory related due to LED initialize stuck on DRAM. Tried reseating everything. Tried single Dimm in A2. Tried the Memory GO button, does not work. Cleared CMOS. Reseated the CPU again. Tried BIOS1 / BIOS2.... Powers up to 2E freezes for 15 seconds, then reboots to freeze on 2E again, and then just stays there until turned off.
G.Skill Trident:
F3-16000CL9D-4GBTD (on compatibility list too)
Rated: 9-9-9-27 @ 1.6v
Motherboard:
Maximus IV Extreme P67 Rev 3.0
CPU:
2600K
Thanks, RC
12-14-2011 06:18 AM
12-14-2011 08:39 AM
12-14-2011 04:01 PM
Kronvict wrote:
I feel so dumb. I found on another forum that the way the dimm sockets are with a clip only on one end you have to push a little harder on the memmory stick on the non clip end and hear a little click to lock it in place. Basically my memory sticks werent fully locked in place. I did that and it booted right up with no problems. Hope that helps.
08-25-2013 12:56 PM
braheem wrote:
Holy... I thought 100% I was sure that the memory sticks were in, pushed the bottom and everything... I just tried with a little more force now and heard the click and voila, no more 2E error code.... was so close to RMA too..
Thanks so much man
12-14-2011 05:22 PM
12-14-2011 05:57 PM
digmeahole wrote:
Wow this is happening to a lot of people it's all over the forums.... Moderator should make a sticky about this as a lot of people think they have dead mother boards or and a bad memory controller. No one is used to this design,. Including myself
