IV formula no post / DRAM LED
kaicastledine
hay guys , i have just finished a new build with the following specs:
.x6 1100T
IV fomula
noctua nh d14
16gb cl9 vengance low profile ram
sapphire HD 5770 vapour x
700watt psu ( its a good make so no need to worry about that )
of corse with other bits and bobs , but the problem is when i first made this rig i had a cpu LED error , this was solved by taking out and putting back in the cpu as i belive the cpu cooler caused abit of hassel . Now with that solved i have another problem , the dram light .......i have tried MEMGO booting , clearing cmos , reseting , taking the cmos battery out , taken it out of the case and used a bench (mobo box) i still have the problem . I have tried every combination with my ram in each slot but still nothing , although with 2 of the time i tested it seems the dram led flashes then goes to the cpu led then back to the dram led again ( like a system restart,, this was fixed by using memgo) any ideas ?
I was thinking of RMA the motherboard or the ram , although i cant find where to start with the rma of the board
14 REPLIES 14
So the only option is some how update the bios ? by using a differnt cpu and maybe ram ...... 😞
HiVizMan
Level 40
That is about it. Maybe a mate or the local PC repair shop can help your with the BIOS flashing. Someone should have a AMD CPU near by.
Just where are you located, I might have a contact close by - you never know.
ive asked round but not many people are happy with taking there cpus out for a couple of hours aha , and Eastbourne :cool:
HiVizMan
Level 40
I guess I can understand that. I take my CPU's out every couple of hours but then I swap out motherboards like some people have cups of tea. So it looks like you will need to take motherboard to PC repair shop type place and see if they can flash for you. Unless it is possible to flash the bios using ROG connect from another machine. Will see how that goes.
I am just up the road from you (West Sussex) so maybe we can make a plan I do have a CPU or two that will work for you.
Well ill give that a go , someone did mention being able to flash it with ROG with a flashmem stick without a cpu ect but ive had no luck personally.If all else fails then maybe a plan could be arranged 🙂
