08-17-201302:47 PM - last edited on 03-06-202408:02 PM by ROGBot
Hi all I have some problem with my ASUS MAXIMUS VI EXTREME - Intel Z87 .
My components are:
ASUS MAXIMUS VI EXTREME - Intel Z87 Corsair AX860i Intel Core i7-4770K Kingston HyperX Beast XMP 32GB (kit 4x 8GB) 2133MHz Kingston HyperX SSD 120GB WD Blue WD10EZEX 3.5" 1TB EVGA GeForce GTX TITAN Hydro Copper Signature
With this components work without problem 1month ,but today i want turn on PC and nothing happened. I checked all components,power cables etc. and all are connected correct. But then i see blinking Q LED - CPU_LED and DRAM_LED. Ram i tested on another PC and working. Then this mean CPU is dead? or something is bad with my motherboard???
I tested this alredy:
1. 1 ram only plugged in on 3nd slot or first + clear CMOS 2. remove and again plugged in CPU(checked pins if not broken)
Sorry for my bad English ,my native language is Czech
ok ,all removed , after 2h re enter cmos battery, connect only 1dram to 3th slot ,power to motherboard + cpu ,grafic card ,then use cmos clearing button and use direct key to bios?
and if this not changet (still cpu,dram led blinking and no signal to display? :D) nnext step try new cpu?
