intel extreme engine utility on maximus iv-z how to enable graphic clocker.
deseroner
i downloaded it and it would show cpu only not hd4000 clocker. any way to unlock it on my 3770k.
maximus extreme iv-z bios 3204
i7 3770k at 4.7 1.35v ivy baby:)
Kingston hyperx genesis 16gb at 2400mhz 12-13-12-32-2
antec kuhler 920.
antec three hundred case
ram fan cooler
corsair psu 850
2xsli gtx670 ftw
raid 0-4 ssd intel 320 80gb x3/intel x25-m 80gb x1
10 REPLIES 10
HiVizMan
Level 40
I take it you have installed the HD4000 graphic drivers from the motherboard DVD?
no, the reason, i got the 3770k , drivers were installed automatic, but i did not install from disc . can i get it from asus website.
antec kuhler 920.
ram fan cooler
corsair psu 850
2xsli gtx670 ftw
HiVizMan
Level 40
You can get it from ASUS motherboard support page. Or if you prefer you can go to the Intel download site and get the latest from there.
Enjoy your system.
i did get the latest one and it did not show up, is the engine mangement driver i need then i can use the extreme utility
antec kuhler 920.
ram fan cooler
corsair psu 850
2xsli gtx670 ftw
HiVizMan
Level 40
Intel graphics driver version 15.22.54.2622 (8.15.10.2622) for Intel® integrated graphics. You have installed this?
Go have a look and see if you can find it here http://downloadcenter.intel.com
i did but no go ,system not compatible ,so driver did not install. i have extreme tuning works only for cpu ,drivers say hd4000, intel driver installed.
antec kuhler 920.
ram fan cooler
corsair psu 850
2xsli gtx670 ftw
HiVizMan
Level 40
OK so your Intel HD graphic drivers is installed.
Have you installed TurboV as yet. It is on the AISuite software pack
Or clock your onboard GPU via the bios.
deseroner
i have had ai suite , removed it, i can clock manual igpu, hmm, if i clock at 1600mhz , what voltage is recommended. by the way i have set my memory timings to 2400 12-13-12-32 kingston 2133, did memtest86 pass 🙂 ivy loves it , no more memory cold boots. yeah any recommendations on oc igpu, will that only net me a 10-15% fps or less on games.thanks
antec kuhler 920.
ram fan cooler
corsair psu 850
2xsli gtx670 ftw
HiVizMan
Level 40
Each CPU will be different you will have to find out what works for your CPU. Start with small steps in the voltage to the IGP and run some kind of stability test for the graphics. Maybe a game loop that will stress the IGP.
Sorry my friend by over-clocking the on board graphics is not something I do often. 😛
