04-02-2014
07:42 PM
- last edited on
03-05-2024
10:08 PM
by
ROGBot
04-02-2014 11:44 PM
04-03-2014 04:42 AM
04-03-2014 06:22 AM
04-03-2014 06:35 AM
04-03-2014 08:29 AM
Myk SilentShadow wrote:
For overclocking, 2 sticks of RAM is better than 4 sticks as it puts less stress on the IMC(Integrated Memory Controller) that is on all CPU's.
04-03-2014 01:13 PM
04-03-2014 02:04 PM
Just1ove wrote:
1 last thing...i have configured a build.
will u guys check it out and warn me if i am doing anything wrong..also 1 of my friend warned me about haswell-e + ddr4 coming out 06/2014 that i should wait for it, should i ?
AMD FX X8 8350 Soket AM3+ 4GHz 16MB Cache 32nm
G.Skill Trident X 16GB (2x8GB) DDR3 2400MHz CL10 1,65V
SEAGATE 3.5" 1TB Barracuda Sata 3.0 64MB Cache 7200Rpm Harddisk
ASUS CROSSHAIR V FORMULA-Z
ASUS R9 290X DirectCU II O.C. 4GB GDDR5 512Bit AMD Radeon DX11.2
CORSAIR Hydro Series H110 280mm Extreme Performance Liquid CPU Cooler
CORSAIR 240GB Force GS Series Sata 3.0 SSD(Read 555MB / 525MB Write)
CORSAIR Obsidian Series® 750D Full Tower ATX Case
CORSAIR RM750 Watt 80 PLUS Gold - Fully Modular PSU
TOTAL = 2500 USD
04-03-2014 02:23 PM
04-13-2014 11:46 AM
TheNerdBench wrote:
Glald to see that you are asking some good questions but seeming you stated that you are a beginner here I need to add some caution...
First start off bench-testing your system with a standard config without the watercooling...for now. Here is a link to help you get started on testing your system BEFORE installing it in the case...I just don't want you to "brick" $2500 worth of computer parts:
http://thenerdbench.blogspot.com/p/bench-testing.html
To answer your question about DDR4 and the Intel question.
First there is always something better on the horizon. Here is the contrast between DDR3 and DDR4 (from Upgrading and Repair PCs 21st Ed)
DDR3 1,000 MHz Base Clock Rate/16,000 MBps transfer rate/1.5V
DDR4 1,600 MHz Base Clock Rate/25,600 MBps transfer rate/1.2V
I can't speak for everyone but AMD vs. Intel is the classic Ford vs. Chevy (when Jeep is the king) but I know for me to go the Intel route would of cost me an extra $400 (which I saved and put towards a graphic card).
So with that said...it is your $$$ so spend it the way you want to! Something to consider though...what forum can you post to that have members who take the time to answer you questions in such great detail 🙂
One more note...there has been some issues I believe with the fans causing problem on the graphic card you listed...maybe try the Matrix version of the 290 (if it is even out yet)...looks very nice with the Crosshair board.
Good luck and post back with "?".
