In need of help
edub404
Okay so i just put my new rig together but i believe im getting a cpu red led and I dont think i should be. I have a 980be and Im not sure what bios im running but my board does say rev1(I THINK) so im a bit confused. Any help would be appreciated.
MOBO - Crosshair V Formula
CPU - AMD Phenom II x4 980 BE 4.2 😄 overclock
COOLER - H60 PUSH PULL
RAM - 8GB G.Skill RIPJAWS X
GPU - HD 6870x2
HDD - 1tb
PSU - Rosewill 630 This PSU is GREAT
CASE - Coolermaster Enforcer
OS - Windows 7 Ultimate SP1 64bit
Simple But Gets The Job Done:cool:
9 REPLIES 9
edub404
Help anyone?
GPU - HD 6870x2
HDD - 1tb
Myk_SilentShado
Level 15
Please list all your hardware so we can help you better 🙂
THANK YOU FOR THE REPLY!
Crosshair V Formula
PHENOM 980BE
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
PSU 630W rosewill green series
COOLER MASTER V8
SAPPHIRE Radeon HD 6870
GPU - HD 6870x2
HDD - 1tb
trailer_park_bo
there is a sticker by the 24 pin connector,the last 4 digits are your bios version,the 980 black edition requires 0602 bios version or later,,another question does it boot,and there is a cpu voltage LED if it boots up and that LED is red that means the cpu voltage is 1.5volts or higher
edub404
The sticker says 1102 and when I connect everything and start it up the cpu led is red constantly. Any suggestions?
GPU - HD 6870x2
HDD - 1tb
trailer_park_bo
can you get to bios, or is it just running the fans,reseat the cpu,check for bent pins,reseat the ram, you probably did all that but thats where i would start looking,also i found it quite challenging to get the ram seated ,,not sure who come up with that idea
edub404
I FIXED IT THANK YOU ALL FOR YOUR REPLIES! I have no idea what i did but i took it apart put it back together and she fired up. Tomorrow I should be getting another HD so ill install the OS and all that other stuff tomorrow.(BTW TECH SUPPORT IS HORRIBLE...DUDE DIDN'T KNOW S***!)
GPU - HD 6870x2
HDD - 1tb
thats great to hear,enjoy the new board
Thnx a lot
GPU - HD 6870x2
HDD - 1tb
