In need of help if possible please and thank you
wrathofkira
Hi OK so I've been having a problem with my rig I believe it started when I installed the 15.3 amd drivers ever since then my PC will shut off the monitors/keyboard and mouse while under load I am using MSI Afterburner and at the time my 1st GPU was around 61 to 62C while my 2nd GPU was around 58 to 59C but when the PC shuts off the monitors/keyboard and mouse the PC it self will stay on and is unresponsive to anything including the power/reset buttons the only way to break it out of that is by flipping the switch on my power supply since then I have uninstalled 15.3 and installed 15.4 and it followed me onto that driver as well I have even went back to using 14.9 and it is still doing this my build is as follows
Case: Cooler Master Haf X
PSU: Rosewil 1000w bronze http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KN...
Mobo: Asus Crosshair V Formula non Z version http://www.newegg.com/Product/Product.aspx?Item=N82E16813131735
Ram: G Skill Ripjaws 8 Gig 2133 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
CPU: AMD 8370 8-Core 4.0GHz 125W http://www.newegg.com/Product/Product.aspx?Item=N82E16819113374
GPU: X2 AMD Sapphire Vapor X R9 290x 8 Gig models in crossfire http://www.newegg.com/Product/Product.aspx?Item=N82E16814202129
HDD: WD Blue 1TB 64MB Cash http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
PS thank you so much for your help and if you need any additional information I will provide what I can
11 REPLIES 11
wrathofkira
I have used that software to remove my drivers and dam dose it work well but I was not talking about my cards I was talking about my motherboard after I tryed watch dogs last night it died and when I tryed turning it back on nothing came on and you know when you then on your PC it starts out low then the fans kick up to speed and loads but it did not even load the bios just nothing and I tryed using one of my 290s and I tryed using my old 580 I even tryed moving the card to other PCI slots I did not get a video signal so I'm thinking my motherboard took its last hit and won't be coming back now
elesde
Ow that does sound bad 😞 I don't think a bios flash will help, maybe if you reset CMOS or remove the bios battery for a couple of minutes.
Just to be sure you could also try a different PSU, if you don't have one at hand and plan on getting a new MB I think you might do better with a new PSU as well.
