Huge difference in Auto SOC Voltage between BIOS versions. Is 1.36V Safe?
ragp13
So after experiencing instability on a new system with DOCP enabled I decided to downgrade the BIOS from 0805 to 0608 for my Asus Prime B550M-A (wifi).
After that, I checked the SOC Voltage in both the Bios and HWINFO64 and the voltage difference when DOCP is enabled for both versions is HUGE!
With the newest Bios it's ~1.085V, with the older Bios it's 1.362V!
My understandig was that anything above 1.2V is considered detrimental for your hardware?
85738
NewEnglandNole
These higher voltages can happen when only a single core is boosting. If you try a multithreaded load you will see the voltage drop because the total current will drop. This is Ohm's Law in effect.
Voltage = Current * Resistance
But is SOC V related to core use? I thought it was for the memory controller?*
I’m not talking about CPU Core Voltage to be clear.*
