04-17-2014 05:49 PM
04-17-2014 06:27 PM
04-18-2014 08:30 AM
04-18-2014 02:30 PM
Veracis wrote:
CHA1-3 have 4 pins and are easily controlled using Fan Xpert in AISuite3. Wouldn't that make them PWM controllable? Furthermore they ask that you set the q-something in bios if you are using a 3pin fan so it can adjust them as needed.
04-20-2014 06:54 AM
05-03-2014 01:55 PM
04-18-2014 08:54 AM
04-18-2014 11:03 AM
12-14-2014 03:34 AM
jab383 wrote:
The chassis fan headers are controlled by seperate profiles in either BIOS or AISuite, but all three profiles are based on the CPU temperature sensor. In that they all depend on CPU temperature, they are not "independent channels." The M6E and M6F have OPT_FAN headers in addition to the CPU and CHA headers. For each OPT_FAN header, there is an OPT_TEMP header. When a temperature sensor is plugged into the OPT_TEMP header, that temperature can be used to control the corresponding OPT_FAN.
Each fan header can drive up to 1 amp. Any fan, or combination of fans on a splitter cable, that totals less than that can be connected. A common approach is to use the sort of splitter cable that draws power from a PSU molex and connects only the PWM and tachometer leads to the MB header. I have pump and radiator fans on that sort of connection now.
In your liquid cooled setup, plan on connecting something to the CPU_FAN header. That's to prevent BIOS from hanging in an alarm condition over the lack of CPU cooling. Radiator fan PWM and tach are good choices. I've put the pump tachometer on that header when fans were all controlled elsewhere.
Jeff
12-14-2014 06:01 AM
