help
rankin_style08
i just installed a crosshair formula-z only the red led light turn on nothing else
can someone help plz ;(
no screen no fan nada just the led light
Praz
There are several LEDs on the board. Please be more specific and also accurately list all the components you have connected to the motherboards. Thanks.
chrsplmr
Level 18
Yes, Please do as @Praz said ...
Check your wiring .. with the PSU unplugged. Special attention to the CPU fan.
[Please be sure you have the right power wires to the correct placement .. no offense to your expertise meant.]
.. and as @Praz stated, supply the list. [is the PSU--'New'?] .. Welcome to ROG.c.
HiVizMan
Level 40
Most often when that happens it means the 8 or 4 pin CPU plug is not connected. Easy fix most of the time.
