help with some basic installation questions PLEASE
EvylCyn
1) Power: Besides the 24pin which others should I have connected? There is an 8pin a 4pin and the 4pin Molex EZ Plug.
Do I need to connect them all/will it hurt anything if I do?
My power supply has the 24pin(which is plugged in)
an 8pin (which says something about intel in the manual but is marked CPU2, but is plugged in)
and another "8"pin which is two 4pins split. One half says CP (which is plugged in) the other the other half says U1
I also have the modular molex cable attached to the EZ Plug- which leads me too...
2) Molex- how much of what can I have plugged into one chain? As of right now I only have one plugged into the PSU with the rear fan, the front I/o panel and fan controller(CM Storm Trooper), and then into the EZ-Plug power on the motherboard
If anyone has the same motherboard...and MAYBE the same case, I could really use some help and would GREATLY appreciate it.:confused::eek:
Case: Cooler Master Storm Trooper
Mobo: Crosshair V Formula-Z
CPU: AMD FX-8350 Lot# 1252PGT
RAM: G.Skill Ares 1866 16Gb (2x8)
HSF: Noctua NH-D14
PSU: KingWin LZP-1000
Optical: LG WH14NS40
13 REPLIES 13
EvylCyn
Thank you guys very much! So if I plug in the PSU to the wall and turn on the mobo to flash the bios, I'm not going to fry anything?
HSF: Noctua NH-D14
EvylCyn
so if I have them like in the photo - the one with the green lines, I'm good? I won't fry anything?
HSF: Noctua NH-D14
lewybear
You'll be fine, they only really fit in one way anyway! If you do damage the board it'll be a difficult job as the board will pull the current it needs you can't push too much into the board.
Rampage v edition 10
I7-6950x @ 4.1ghz
Dominator platinum 32gb @ 3000mhz
NZXT X76 Kraken 360mm rad cooler
Corsair ax1600i psu full white cable set
Samsung EVO 970 1tb M.2 boot
Samsung EVO 850 1tbx4 SSD raid, storage
Titan xp jedi collectors edition
NZXT Phantom 820 full fan set
ROG frontbase
Samsung 55" 1000hz (140hz effective) 4k hdr tv as monitor
Windows 10 pro 64bit
EvylCyn
Fired her up and flashed the newest BIOS from asus website. Can't wait until I get my storage and video:D
HSF: Noctua NH-D14
