1) Power: Besides the 24pin which others should I have connected? There is an 8pin a 4pin and the 4pin Molex EZ Plug.
Do I need to connect them all/will it hurt anything if I do?
My power supply has the 24pin(which is plugged in)
an 8pin (which says something about intel in the manual but is marked CPU2, but is plugged in)
and another "8"pin which is two 4pins split. One half says CP (which is plugged in) the other the other half says U1
I also have the modular molex cable attached to the EZ Plug- which leads me too...
2) Molex- how much of what can I have plugged into one chain? As of right now I only have one plugged into the PSU with the rear fan, the front I/o panel and fan controller(CM Storm Trooper), and then into the EZ-Plug power on the motherboard
If anyone has the same motherboard...and MAYBE the same case, I could really use some help and would GREATLY appreciate it.:confused::eek:
Case: Cooler Master Storm Trooper
Mobo: Crosshair V Formula-Z
CPU: AMD FX-8350 Lot# 1252PGT
RAM: G.Skill Ares 1866 16Gb (2x8)
HSF: Noctua NH-D14
PSU: KingWin LZP-1000
Optical: LG WH14NS40
