06-11-2017
09:18 AM
- last edited on
03-05-2024
09:49 PM
by
ROGBot
06-11-2017 11:11 AM
06-11-2017 02:56 PM
davemon50 wrote:
Nice job listing all this pertinent information. 😉
OK, so just to confirm what you're doing, you have W10 installed on your WD-1TB drive, AND you now want W10 on your new M.2 drive (presumably to make this the new bootable Windows drive), AND you are installing it to the M.2 from a bootable USB created by your existing W10 OS on the WD-1TB drive, right?
You have a different motherboard, so you might've missed THIS THREAD by chino, but check it out as it still may help you sort this out.
Since you have a bootable USB check whether it is formatted as FAT32 or not. You should know if you haven't already discovered, that Windows installs don't always play nicely when you have an existing installation elsewhere on the computer. If that's what you have, then my recommendation would be to do a shutdown, then disconnect your WD drive SATA port and power cable, then boot into BIOS and ensure that legacy drives are enabled and change your boot sequence to boot off a USB drive. Also may be good to temporarily disable fast boot. Check the chino thread above and see if you can't get further.
Chino wrote:
For Samsung XP941 owners, you're stucked with UEFI. Since the UEFI driver is embedded into the firmware itself, you will have no problems installing in this mode. The problem arises when you want to do a legacy installation because it requires a driver to be loaded during the installation process. With the XP941 being an OEM product, there are no drivers available to install in legacy mode.
06-11-2017 03:53 PM
davemon50 wrote:
I had a similar issue with my M.2, the motherboard did not recognize the M.2 drive until several boots later, I don't recall how many but at least 3.
06-11-2017 06:43 PM
06-12-2017 02:37 AM
06-12-2017 11:23 AM
ReformedSS wrote:
You wouldn't be able to see the SSD in the BIOS until you installed windows as it will install its own drivers and afterwards you would need to find the right drivers for the SSD. But I can't even see it during the install.
06-12-2017 12:28 PM
06-13-2017 10:14 AM
