help Required , for hitting 5.1ghz or 5ghz on IVY BRIDGE 3570 on Maximus V Gene
YJK
Hi guys i need a help to overclock my 3570k to 5.1ghz on Maximus V gene , kindly share the bios settings that will be fruitful
for me.
here are my system Specs
Ivy 3570k
Maximus V Gene
Corsair H100 Liquid cooler
4gb Adata 1600mhz CL7 Ram
Case Haf932
sorry for mistype its 3570k
[B]Guns Are Neat Little Things, Aren't They? They Can Kill Extraordinary People With Very Little Effort.
18 REPLIES 18
HiVizMan
Level 40
Hello
Welcome to the forum, I can tell you right now that you are going to struggle to get 5.1GHz on the cooler you are using.
What you should do is read Raja's guide and work your way slowly up the multipliers and adjust your voltage in small steps. Keep an eye on the temperature, use only one application for monitoring your temperature and look at the individual core temperatures.
I would think that 4.6 or 4.8 GHz would be the maximum that the H100 cooler could handle.
What is your ambient in the room where the PC will be kept?
Zka17
Level 16
Are you looking for a 24/7 OC at 5-5.1GHz? I would say, forget it! With that cooler and an Ivy Bridge... - it will run very hot...
You may be more lucky with your 3570k then I'm with my 3770k, and need lower voltages for that speed, but the H100 is still not enough... maybe, if you just want a CPU-Z validation or something similar (for short term and no stressing), you can do it...
bro not for 24/7 , just for some benchmarks , thanks for a reply , where i can get that guide ?
bro thanks for the reply , iam looking for a just to benchmark not for 24/7 , any help will be fruitfull
HiVizMan
Level 40
Even for benchmarks it is going to be tight completing the run. I would suggest reading Zka's log and trying the chilled water route if you want to bench.
iam new in this forum can u send me the links i shall be thankful for ur cooperation
Zka17
Level 16
You can click on the "The Chronicle of My TestBench" in my signature... post #100 and #107...
i need help ,, basically i had a msi mobo Z77A-Gd65 with a same processor , my system was stable on 4.8ghz with 1.45vcore ... now on iam maximus V gene , couldnt stable it to 4.8ghz , how can i stable it and i wanna oc to 5ghz ... but my attempts are failed seriously need a help
bios settings snap shot will help me , cause iam new on Rog board
Zka17
Level 16
So, you're on Maximus V Gene with a 3770k... if you want to OC, my first question is: how you're cooling your CPU?
In my case, 4.8GHz is stable only with Vcore at 1.53... whit those settings, the 3770k produces a lot of heat! As you can see in my thread (link in my signature), I'm using custom water cooling: a 3x120mm radiator with 6 fans in push-pull configuration - temps are maxing out during stressing (AIDA64) at 85C on cores, idle below 30C...
With your H100 practically is impossible to get a 5GHz OC on the CPU... simply, the H100 isn't enough for that heat... if you have very good airflow through the H100's radiator, but I mean really good airflow, maybe you could do 4.8GHz... sincerely, for a 24/7 OC, I would stop at 4.6GHz...
I could post some snapshots of my BIOS settings, but the thing is that every CPU is different... I think, mine is a little degraded already as I used very high voltages during benching... if you really want to learn OC'ing, I would advise you to start reading the stickies on this section...
