[Help] Overcloking I4770K withe Maximus VI Gene
Fraizer
Hello all 🙂 (sorry for my bad english, french inside ^^)
I want your help to Overclock my 4770K Batch L310B479 withe Asus Maximus VI Gene
I have Kingston Hyperx Predator 16GB (4GBx4) 2400mhz (KHX24C11T2K2/8X)
http://www.kingston.com/datasheets/KHX24C11T2K2_8X.pdf
I use for cooling a Corsair Hydro H80i (after i found the good OC i will delied (remove the ich) the cpu i already done this withe a 3770K and i loose like 15°c)
by searching in many forums i found this cpu withe my batch... people OC this one to 5.0ghz.
By readin i understand the OC withe Haswell its different and some people dont knwo OC this new cpu in the bios... this why people think this cpu its bad. (i just repeat what i read ^^).
Please can you help me to OC this cpu and optmise the stability by playing withe Vols options ? (i am verry bad withe this.. i try to read difference post explain volts oc (except of course the vcore) but i dont understand well...)
for the moment i dont try to OC my CPU
thank you for your help
EDIT: its my personal computer, for playing 3D games in high resolution, Photoshop/indisign & video (withe a Nvidia GTX 690 4GB)
16 REPLIES 16
HiVizMan
Level 40
OK what you have is an example of how two CPU's with the same batch number behave very very differently. The 1.2625 voltage is a base line test. That your CPU will not post OS shows me it is not a CPU that will overclock much at all, and will need lots of voltage if you do try.
My CPU will boot into OS at 52x with 1.2625 but is not stable there, at 50x it is stable with 1.2625 however I have another CPU as you saw in that other thread that is like your one.
RAID yes you got it right.
killrog
with h80i u shouldnt be using more then 1.20v (1.25v max) cause you going to reach 95c+.
If u going to use c6 c7 energy saving, 1.15v max voltage (adaptive adds upto 0.1v).
Last. read http://www.overclockers.com/3step-guide-to-overclock-intel-haswell
Fraizer wrote:
oh then its not from the bios option ?
thank you Praz i completly miss i make new installation of windows
You're welcome. 🙂
C6/C7 States have nothing to do with the AVX voltage increase when using offset or adaptive voltage modes.
Fraizer
its sad for me 😕
HiVizMan to have beter cahnce to have another CPU able to have a better OC what you recomand me to do ? i knwo its not rules... but maybe i have to wait a new revision ? or maybe better for me to order to amazon.co.uk (i order this one from amazon.fr) if you have any info its will be nice
ps: i make a new windows installation and now its ok
thank you killrog (i disable all c state i dont knwo if its good idea).
yes the h80i its not verry good but i will delied the cpu when i found a good one or maybe this one i already have 😕
Fraizer
can you tell me please what options in bios i need to activate or disable to have just 1 speed oc CPU the full speed target of the oc because i have this : my speed go to 3500 to 4000 and 4600 etc... its up and down in cpuZ i just want 4600mhz...
(its hard for me the VI version all its so easy withe the V gene...)
thank you
Praz
Set the Windows power plan to high performance.
Fraizer
