help offset
andrea89
Hello
Guys I would use the offset ...
but do not know how to set it!
now fixed voltage to 1.320/1.328
If I want to use the offset as I have to set, to have a low voltage at idle and in full in 1.328?
thanks
CASE: Obsidian 800d MB: Rampage IV Extreme Cpu: Intel I7 3930K@ 4.7 OFFSET 1.328\1.336 Cooler: H100I Ram: 16 Gb Corsair Platinum 2400Mhz C9 Gpu: EVGA GeForce GTX TITAN Superclocked Signature 6 GB Ssd: samsung 840 Pro 256 Gb+samsung 840 evo 120 Gb+ASUS ROG RAIDR Express AUDIO: ROG Xonar Phoebus 7.1+ logitech Z-906 MONITOR: MX299Q ULTRA-WIDE 21:09 ALIMENTATORE: Corsair AX 1200i OS: Windows 8.1 pro 64 bit ROUTER: DSL-N66U
29 REPLIES 29
Arne_Saknussemm
Level 40
Hey there andrea89
To use offset you have to also be using a normal value for BCLK....I say this just in case you are OCing using the strap 1.25 or something like this.
So finding offset is not a simple sum most times. Basically if CPUz is showing you 1.32 to 1.33 during load you have to try a few offset values and test at load again until CPUz shows the same voltage.
So try the minimum offset first like + 0.005 and see where that gets you or values like +0.01.....0.025 or you can try a negative offset like -0.005 if you noticed that your default Vcore on auto was a lot higher than your manual voltage.
This is a good thread on offset.... http://rog.asus.com/forum/showthread.php?2162-Overclocking-Using-Offset-Mode-for-CPU-Core-Voltage&co...
Just make sure speedstep is enabled in BIOS for this to work and be careful if you are using Windows Performance power plan that in Advanced settings Minimum Processor State is set to something like 10% 🙂
andrea89
Yes BCLK is in default
perfect I like you told me ...
I know!
Thank you!
PS
Do take a look at the offset thread
Arne_Saknussemm
Level 40
Arne Saknussemm wrote:
What OC are you running at 1.32/1.328?
4.7Ghz HT: off
Arne_Saknussemm
Level 40
That is good voltage for that clock! From what I have seen lower clocks can use negative offset often and then higher clocks seem to need positive more often than not. Your chip seems to be good with voltage so I'm not sure what to recommend...
Maybe try minimum negative offset (-0.005) or if not switch to positive and try a few values just check CPUz under load to see what your new voltage is and test stability....
HiVizMan
Level 40
Multi x47
Voltage - offset
Offset + 0.005
Set LLC to medium or regular
Leave all else on auto
Run some stress test for a few minutes to test temps and some rough stability testing. Best stability is to play your favourite game or do the work that your system was bought to do.
HiVizMan wrote:
Multi x47
Voltage - offset
Offset + 0.005
guys I did a little test
offset -
+ o.oo5
llc on medium or regular
but it gave me bsod after several hours of play ....
1.320/1.328 V while the voltage was monitored played with cpu-z
Now if I would take one step more in V else what should I do?
type 1.328/1.336
tnhx
Arne_Saknussemm
Level 40
If it BSODs ( what code by the way?) on both Medium and Regular LLC at +0.005 just ry to increase a bit +0.01....+0.015
But not all BSODs are vcore related but I guess you know that....:o
Clock Watchdog
yes bsod code 0x00000101
I then try 0015 I know!
Thank you!
